cruise control/turn signal help
Discussion in 'Modifications And Maintenance' started by RichWRX, Oct 28, 2007.
  1. RichWRX
    RichWRX Well-Known Member
    My cruise control on my 99rs doesnt work, are there some common things that might go wrong with it I should look at? when you press the cruise control switch on the dash should a cruise control light be on the cluster? if so mine isnt.
    And my right turn signal doesnt work, when I put it on the lights on the cluster dim and it makes a weird clicking noise. Could it be the switch or a relay?
    I spent most of the day ripping out wires that the person had running all over hopeing there was a short somewhere. I disconected the led nozzle lights, the neon gas and brake pedal, and the neons under the seat. I didnt really want to do it because it was so cool:laugh:
  2. 02blubru
    check your other turn signals they will do wierd things when one burns out.
    as for your cruise check the fuse and your brake lights. My dads car's cruise quite when one of his brake lights were burnt out. Other then that I have no idea.
  3. RichWRX
    just checked all the fuses and the turn signal relay and they are good. The bulbs are fine also
  4. 02blubru
    well I am out of ideas...
    Chux???
  5. Impreza
    Impreza Well-Known Member
    Did you check the little black air hose that comes from the cruise control silenoid to your intake manifold?
  6. RichWRX
    checked it, hose was good:dunno:
    I have the whole car ripped apart now, carpet seats, doors and dash. There are alot of wires that i took out that who knows what they were for.
    When I use the right turn signal I noticed the turn signal relay gets really hot after a couple minuites.
  7. rsverv
    rsverv Well-Known Member
    there is no light on the cluster. the only light that lit is the light on the switch.
  8. AWDimprezaL
    the cruise switch itself should light up...then agian i have the older style
  9. RichWRX
    I wasnt sure if there was a light or not, I know my sti and wrx had one. Was just assuming the rs would.
  10. Ravyn
    Ravyn Well-Known Member
    My RS has a light on the button itself, and when I bought it, it wouldn't light up, and the cruise control didn't work. I had the shop take care of it as part of the final purchase agreement. I guess I only mention it to say that there is a light in the button and it wouldn't light up when the cruise control wasn't working.
  11. RichWRX
    Thanks, My button does light up. I think I may have found the problem, just havnt had a chance to drive it since its still in pieces.
    I just need to figure out the turn signal now, anyone have a turn signal swithch laying around?
  12. Bielke55
    I had one... but it was busted worse then your problem. It would click the high beams on and off very fast, when ever i touched it.
    Also i have a full working Cruise Control system from my car if you need parts. Also Full A/C system (one hole in main hose though)
  13. RichWRX
    Thanks, I will let you know if I need it
  14. RichWRX
    does anyone have a turn signal swith that would fit a 99rs?
  15. RichWRX
    I still cant get the cruise to work, what do you want for the cruise control?
  16. Bielke55
    Let me gather the parts the together i'm sure we can work something out.
    What parts do you need for sure?
  17. RichWRX
    I dont really know what I need, all i know is that the button lights up and the cruise wont work, I checked everything that I could
  18. Bielke55
    Hmmm okay...
    I have the main unit out of the car... and i can possibly pull the Module if you need that too.
  19. RichWRX
    why dont you just come to the ice race and put it in for me ;)
  20. John16V
    John16V Well-Known Member
  21. RichWRX
    no I havn't, i will try that when I get some free time.
    Thanks
  22. driftin240
    driftin240 Well-Known Member
    Rich, check your clutch pedal. There should be a little white button that sits on the pedal stem somewhere up top where the cruise switch. If it has a hole in it, that's your problem. It most likely is it...
  23. driftin240
    Here's a pic of the little thing.
  24. driftin240
    And I also have a turn signal switch from an 06 legacy...which I bet will fit in your car with no issues.
    I would double check that all the bulbs flash at the same rate, and the same time. I have seen people wedge the bulbs in backwards and that causes awkward flashing.
  25. Chin
    Chin Well-Known Member
    My Cruise in the '00 RS hasn't worked since '02... Did everything except change out switches. Never did figure it out, not that it matters any more.
    Christian
