Ok guys, I have a buddy, actually a very close friend that sold his 04 STi this summer. Over the winter he had purchased the above mentioned coil overs with the dampening control unit that mounts inside the car to controll all four corners but never got them installed. the car is long gone, but the coils are still in the box from gruppe-s and collecting dust. He is not a member on here so he asked me to post them up so I can get people in contact with him. He is looking to get $1600 for these picked up locally. these units go for anywhere form 2300 to 2700 if you do some searching online. Here is a little info on them I copied from a site. Cusco Zero2E - Brand New!!! Cusco heard your request, and have now answered with the all new Zero-2E system. With all the same benefits and features as the Zero-2 coilover, the Zero-2E adds the option to electronically control the shock adjustment from inside the car. Utilizing the E-Con (sold separately), you can select what stage (of 5) you want the shock set at. With great features such as: Electronically controlled shock adjustment (w/ E-Con) - Pillowball upper mounts - Adjustable shock casing - Independent adjustable spring perch - Stainless steel thread body - Stainless steel case lock nut - Stainless steel spring perch/lock nut - Specially coated lower bracket Performance! Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance! Comfort! Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers! Strength! Larger size pillowball used in the upper mounts. Endures through the hardest drives! Setting! Height adjustment and spring pre-load are designed to be adjusted independently. Lower your car with the adjustable shock casing while retaining the overall shock stroke. Set the spring pre-load to your desire and feel the difference in driving and traction. Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered. - New design: Side port rotary valve - New: Reduced friction piston - New oil reducing cavitation - New material: Special steel for piston valve shim Anit-Rust! Worried about rust? No problem with the Zero-2E’s stainless steel lock nuts, lower seat, and threads. With the external cylinder and threads being stainless steel, adjusting the height will be smooth. The lower bracket/case has a new special coating as well. The internal as well as the external surface has been coated. *be sure to always clean the threads prior to adjusting the height. Road debris and brake dust can settle on the threads causing difficulty in smooth adjustment. Springs rates are 7 kg/mm front, 5 kg/mm rear. You guys can call me @ 952-240-4001 Matt UPDATE!!!!!! THESE NEED TO GO, I PREVIOUSLY FORGOTT TO MENTION THAT THE REAR ALSO COME WITH THE CUSCO ADJUSTABLE CAMBERPLATES. ALSO MY BUDDY IS WILLING TO THROW IN A CUSCO INTERCOOLER SPRAYER CONTROLER/TIMER FOR FREE HE HAS!!!! $1600 PLUS SHIPPING TAKES IT ALL.
I have these on my 06 STI and they kick ass!! Oh they also do well in the snow haha Depending on price I am willing to buy the econ unit.
LOL I know he isn't willing to go that low. We will put them up on Nasioc in a week if we have no biters here, just wanted to sell them to someone local and not have to go through the hassle of shipping them.
BUMP!!!! Still for sale Also, if anyone is worried about installation, I will install for a very reasonable price!!
Reduced Price And Several Items Added For $1600 Plus Shipping Previously Forgot To Note That There Are Cusco Rear Adjustable Camber Plates With These And Also A Cusco Intercooler Sprayer/timer Unit.
