custom exhaust
Discussion in 'Modifications And Maintenance' started by mnstilynwrx, Sep 26, 2005.
  1. mnstilynwrx
    mnstilynwrx Well-Known Member
    does any body have a custom exhaust for there 02 wrx? iam going to get one done for me, it will be three inches from the turbo back and i was wondering if that would through of the o2 sensors or if there would be any sort of problems with that. also if i do that will there be enough back presher for the engine?
  2. Deride
    You don't have to worry about backpressure, I think there is a o2 sensor fix you can buy so you don't get a CEL. What are you running that you need 3inch exhaust for?
  3. mnstilynwrx
    iam planning on getting a biger turbo maybe a PE181 or something else
  4. Justin
    Justin Well-Known Member
    search on nasioc. there are many good brands. Just make sure its 3in all the way through, and has a bellmouth down pipe and you will be good.
  5. AWDimprezaL
    I'll be running 3-in turbo back, even with this small snail...you want as little restrictions as possible on a turbo car, even if its stock
  6. mnstilynwrx
    where do you buy an 02 sensor fixer so my check engine light dosent come on? does any body know
  7. TSTRBOY2004
    build it... there is a thread here or on nasioc to do it.. takes like 10mins and costs about $5
  8. mnstilynwrx
    if you find that thread or know where it is can you let me know thanks, i cant seem to find it. must be not typing the right words.
