Does anyone have any experience with these Radiators? I have seen the threads on Nasioc, many have good things to say about the products. Seen a couple who have had some leaks, but company took care of it. Just wondering anyone else thoughts or experience with the $110 shipped for an aftermarket Aluminum radiator. http://www.ebay.com/itm/CXRacing-FU...-2-Rows-Dual-Core-02-/180777722688#vi-content
I have the same radiator on my 03 wrx and it fit perfectly with the stock fans and caps. Just be sure to replace the drain plug with a brass NPT threaded unit so there is no chance of leaking and apply a tiny bit of teflon tape just to be safe. also depending on your overflow tank configuration you'll need a small section (4-6 inches) of coolant hose and a "T" fitting to connect the new radiator overflow nipple into the line that runs from the turbo coolant resivor into the overflow tank on the driver side. I've had mine for about a year and its performed flawlessly and my car cools more efficently
