Damaged tire during dismount
Discussion in 'Modifications And Maintenance' started by predavore, Sep 24, 2007.
  1. predavore
    predavore Well-Known Member
    I got a set of Blizzaks for my girlfriend's car. One of the tires (as far as I know) has some damage on the inside edge of the lip. How bad is this? Will this be okay? Tire guys? 1_sic_rex? What do you think?
    Derek
  2. Taras
    Taras BANNED
    does not look too bad to me.
  3. Squiggly
    Squiggly Squiggly
    looks fine to me but im not an expert
  4. subytek
    subytek Well-Known Member
    I think you would be ok to run it.
  5. AWDmadness
    AWDmadness Active Member
    Do you see the nylon cords? i think it may be junk but when you take it somewhere to have mounted just ask them if they will mount it for you. it looks like it will hold air. good luck
  6. speedyham
    speedyham Well-Known Member
    As long as you can't see the steel cord through the rubber right there is is fine. If you can see steel it's junk, as the steel will rust and the sidewall of the tire will separate from the bead.
  7. blackozone
    That should be fine, the area where the sealing takes place looks like it's undamaged. You will be safe.
  8. TSTRBOY2004
    looks ok... cosmetic by the looks in that bad pic... get some bead sealant and run around that edge then remount!!! I have mounted worse and never had leaks...
  9. Vector
    Vector Rally Organizer
    I agree with Nathan. It looks mostly cosmetic, but bead sealant is cheap insurance. Especially on snow tires with soft sidewalls (even more so the Nerf tires that Bridgestone calls Blizzaks).
  10. predavore
    I added another crappy picture. Does that one help?
  11. Vector
    It's the outside of the bead that seals against the rim, not the inner area, so it's not a problem.
  12. TSTRBOY2004
    yeha it doesnt look like it is truly the 'bead' part of the tire...
  13. flstffxe
    flstffxe Well-Known Member
    You are correct sir
  14. Shibbs
    We just had a car tonight that had a bead destroyed very similar to that. We replaced it, but it did hold air. Not gonna guarantee that it'll seal corectly forever tho.
