Dead Sexy....
Discussion in 'Modifications And Maintenance' started by piddster, May 5, 2006.
  1. piddster
    I was going to assemble this weekend, but I found a clump of shavings from boring near one of the oil squirters. I'm gonna have them tank the block again before I put it together.
  2. Dream
    mmmmm very nice. Full list of mods?
  3. readymix
    Looks to me like a full 22T with forged rotating bits ;)
  4. slavboy1
    slavboy1 New Member
    Schwing!!
  5. readymix
    BTW, what crank is that?
  6. piddster
    Well.....
    1991 EJ22T engine
    Eagle Rods
    Wiseco pistons .020 over
    Stock Crank (EJ22T)
    Bottom end balanced with flywheel and pressure plate (6MT)
    -He didn't have to touch the crank, it was "perfect"
    New water and oil pump
    Cams redone by Delta
    Rebuilt heads
    Garrett GT2871R .86 A/R turbine section
    Speacro IC, core @ 26 x 6.5 x 3.5 Bar and plate
    JECS 650cc side feed injectors, actually for sr20det, but work with N/A rails
    Walbro fuel pump
    Zeitronix wideband w/ EGT and 3.5 bar MAP(MAP will be used for EM as well)
    Still need EM, been looking at the Link Plus G2
    Autometer Cobalt boost, water temp, oil pres. gauges
    '05 STi 6MT
    Stock STi clutch, should handle what that turbo can do
    STi Group N Engine & Tranny mounts
    This is all going in my '93 Forest Pearl Legacy (only sprayed that color in '93, and have yet to see another). My lower radiator support is mangled from the deer I hit a year and a half ago, so that needs to be repalced. I'm gonna shift the radiator back as far as I can with some SPAL fans, so I can put the IC behind the headlights. My AC is gone and will never return, so screw it. Plus, it will make my IC plumbing ALOT shorter and easier to manage. Eventually I'll mold some fiberglass or carbon to duct the air evenly and take the place of the grill. I'll also have to use two locking hood pins since the vertical support with the latch is coming out. Oh, and I'm doing a rotated mount on the turbo as well.
    I still need a bunch of odds & ends, such as a BOV, 3.9 rear diff, hood, IC plumbing, turbo cross member, turbo radiator, SPAL thin fans, WRX/STi cluth/brake pedal assembly with clutch master and slave cylinders, driveshaft from an automatic, SS rear vented brakes, Silvia dump pipe, cheap WRX 3" turbo back to cut up and make it work.
    As far as the rest of the car goes...
    H&R coilovers
    STi Group N strut tops
    Energy Suspension kit
    SuperPro steering rack, diff support, tranny cross member, rear lateral link bushings
    Whiteline anti-lift kit
    RacingBrake 4 pot front brakes w/ Hawk HPS pads & goodridge lines
    I still need to get a Whiteline adj. rear bar, and possibly a bigger front bar, as I'll see once I get a rear bar (Legacy L models had no rear bar in '93 :eek3: )
    Ummmm, I think thats it.
    More pics here : http://www.d.umn.edu/~pidd0002/Car Stuff/
  7. Dream
    Very nice, sounds like its gonna be a beast!
  8. LVT
    LVT Well-Known Member
    very nice! keep us updated!
  9. asiandude
    asiandude Well-Known Member
    very nice set up
  10. Dynapar
    what this is gonna be a monster
  11. snbrd4evr
    snbrd4evr Well-Known Member
    Geez... so many projects going on at the same time. When are you planning on finishing that beast? When everything is said and done we're really going to have to get together and have some fun up in the woods ;)
  12. piddster
    I'm hoping by about the end of the summer. I need about $3k worth of stuff to get it going. That and lots of elbow grease, cut knuckles, and *choice* words. ;)
