Decelaration noise
Discussion in 'General Subaru Discussion' started by 02blubru, Sep 24, 2005.
  1. 02blubru
    When I am in say 3rd gear and let off the gas as my rpm drops I get a funky noise, but if I touch the break, gas, or clutch it instantly goes away. Anyone know anythign about this.
    BTW, it is on a 02 stock wrx
  2. LVT
    LVT Well-Known Member
    if its still under warrenty, have the dealer check it. It should be covered under your driveline.
  3. Chin
    Chin Well-Known Member
    Nowhere near enough info to help....What does it sound like? "Funky noise" is no help when determining root cause. Where does it come from? When you say "touch" are you referring to resting your foot on the pedal or pushing it? The more description you add...the more likely you will get useful help.
  4. prezawagon
    prezawagon Well-Known Member
  5. 02blubru
    it alsmost sounds like a vibration of the heat shield but I checked those and they are not lose. also the noise sounds like it is coming from the lower engine/ transmission area. In terms of touching the pedals it as soon as I start to apply pressure to them the noise goes away.
  6. 02blubru
    the car is out of warranty :( and I did just jack my car up but it was just to get ther RF tire off..
  7. Chin
    So it doesn't sound internal to the tranny?
    If not, could it be under the dash? Being that the pivot point for both pedals is there, it would be a logical start.
    The trick is to find out what the clutch and brake have in common... Other than under the dash or through the firewall, I don't think they share anything... however, they are both mounted to the firewall (brake booster and clutch cylinder). Don't know where else to point you, sorry.
  8. dezavu
    dezavu New Member
    this might not help, but on the ford crown vics, the one i drive at work, there was a similar problem with the car. it turns out that the oil pump needed to be replaced... this might or might not help you at all... had nothing to do with the exhaust, thought it did sound like the heat shield was rattling.
  9. 02blubru
    Thanks for the help guys, I will start doing some more digging and checking on my car.
