I've recently installed a defi d gauge for egt duty and it works ok but sometimes sticks when sweeping on start up and even when its cold it'll start out at 600 degrees even though I know its not that hot. Some times it'll do it other times it won't. Is there any fix for this? I bought them used as a set of egt, boost and oil pressure in an ati pod. Is there anything I can do with the motor inside of it to fis this problem? Also when I installed the egt temp probe in the exhaust mani I didn't use any loctite, is this going to be a problem? I don't really want to rip it all appart again, and its not leaking at all. Should I disassemble and locktite it??
