DEI Cry02 IC Sprayer Kit
Discussion in 'Modifications And Maintenance' started by 6MTizzle, Aug 2, 2006.
  1. 6MTizzle
    6MTizzle 2SLO
    South Side
    Anyone ever tried one of these. In principle they should work great. Just wondering if anyone has actually run one before.
  2. Sogonerg
    Sogonerg Anteater
    Earth
    I was thinking about it as well...But didn't buy anything yet...
  3. 6MTizzle
    6MTizzle 2SLO
    South Side
    I wanted a little more power without affecting my tune...I've currently got an up-pipe project I'm working on then I'm getting the Koyo radiator altho I may get this first.
  4. readymix
    Eloh, El
    You will need to be tuned to make use of it.
    *EDIT* Get the radiator. It will be more beneficial for the dollar. The Cryo2 kit costs nearly the same amount as the Koyo radiator. I was going to get a CO2 sprayer before I got tuned last time. I mentioned it to Jorge, he said, "You'll want to get that before the tune because it needs to be tuned for."
  5. 6MTizzle
    6MTizzle 2SLO
    South Side
    ^ Isn't it essentially the same thing as driving in the winter(colder air)?
  6. readymix
    Eloh, El
    No. In the winter, ambient temps are below 32 degrees...and your ECU measures ambient temperature...not intake charge temperature. It assumes the intake charge temperature will be close to ambient temperature. If you cool your intake charge to 32 degrees with a Cryo2 system and the outside ambient temp is 90 degrees, your ECU will be expecting an air density that is based on air that is 90 degrees and will actually get air that is more dense due to it being chilled by the Cry02 system.
  7. 6MTizzle
    6MTizzle 2SLO
    South Side
    I see...if this is the case this may not be a viable option for me.
  8. readymix
    Eloh, El
    I would definately save your money and get your radiator upgraded. Maybe even a big oil cooler. Those two items will help you alot more.
  9. Dynapar
    Orono, MN
    pete why dont you just make your own cry02 kit. i bet we could piece one together pretty cheap.
  10. readymix
    Eloh, El
    That too. I had a sprayer ring lying around. It is pretty easy to make. You can make yourself a setup that is good for a few shots with a 20oz CO2 canister for paintball guns, some steel braided line and some paintball air fittings. You'd also need some sort of valve. Could probably be done for under 100 bucks
  11. 6MTizzle
    6MTizzle 2SLO
    South Side
    Well if a tune is required even a dyi one isn't an option for right now...maybe down the road tho. Radiat0rz first methinks.
  12. Sogonerg
    Sogonerg Anteater
    Earth
    I agree with the Radiator, I already got mine a while back and it helps...Honestly the Oil cooler didn't help much, other than taking space in my engine bay, so I pulled it off...I agree on tuning your car with the cryo as well, But I've read some folks installing it and not getting tuned, and it still gets you about 20-30hp, but it throws off your MAF. If your tuned for it I think you can push it to 50+hp. The only reason I why I would get it, is to help the lag from the bottom lower RPMs to get the turbo spooling....And no, not the VF34, I'm planning on going bigger.
  13. Sogonerg
    Sogonerg Anteater
    Earth
    Let me know what price u end up with the radiator...Maybe I can get it a lil bit cheaper...
  14. 6MTizzle
    6MTizzle 2SLO
    South Side
    I'll probably do the radiator once Perrin ships back the correct lower ic hose. I'm going to give Josh a call at import image and then I'll let you know, Ray. I'm going to pick up one of the Koyo's.
  15. Sogonerg
    Sogonerg Anteater
    Earth
    No problem...
  16. readymix
    Eloh, El
    The price on the Koyo's has gone up. I've seen 385 shipped.
  17. Sogonerg
    Sogonerg Anteater
    Earth
    ^ Where at? that is a good price...
  18. Dynapar
    Orono, MN
    i was thinking about making a IC sprayer for my car when it was turbo. just use a 5lb tank or something maybe even a 20lb or 50lb tank and spray NNNAAWWZZ on it for extra power lol.
  19. readymix
    Eloh, El
    There is one on eBay right now for 344.99 + 40.00 S&H. Search "WRX Koyo" they should come up.
  20. Dream
    south
  21. readymix
    Eloh, El
    The one for 385 on eBay is for 2002 WRXs. It is 390 for the 03+ WRX and STi fitment.
