I have a current Group Buy going on for DevilsOwn Water/Meth injection kits. The main function of the DevilsOwn water methanol injection kit is to suppress detonation caused by high temperature and pressure developed within the combustion chamber when the effective compression ratio has been taken beyond the auto-ignition point by either a turbo or a supercharger. Cool the air with the alcohol water injection kit! Water, with its high latent heat content, is extremely effective for controlling not only the onset of detonation but also the production of oxides of nitrogen in the modern lean burn engines. Methanol with its 116 octane and high flash point and specific gravity further reduce the chances of detonation. Benefits Of Water-Methanol Injection: Increase horsepower safely by 10-15% Lower air temperatures by 50-200+ degrees Increases octane when you need it under boost. Reduces cylinder temperatures up to 300+ degrees No wear issues only clean combustion chambers Allows you to safely run more boost and timing There is 2 Options here. Universal Stage 1 View attachment 25027 System Contents Include: Adjustable pressure switch 250 psi pump with EPDM seals Heavy duty nickel plated check valve 15 ft of black high pressure nylon tubing 2 Micro droplet nozzles DO3,DO7 Filtered self sealing tank tap All necessary hardware Detailed Instructions Important Notes: Basic hand tools required for installation Proper tuning is required to achieve maximum results Typical install time 2-3 hours Or 2.5 Bar Stage 2 View attachment 25028 System Contents Include: Digital Progressive Controller (fully adjustable) 250 psi pump with EPDM seals Heavy duty nickel plated check valve 15 ft of black high pressure nylon tubing 2 Micro droplet nozzles DO3,DO7 Filtered self sealing tank tap All necessary hardware Detailed Instructions Important Notes: Basic hand tools required for installation Proper tuning is required to achieve maximum results Typical install time 2-3 hours Prices Stage 1 $210 retail price is $240 Stage 2.5 $310 retail price is $360 Prices do not include shipping. No need to wait for anyone with this group purchase. Just contact me to order!! As always installation is offered, and highly suggested with this product. Also tuning is suggested. Contact me to order, for installation quotes and nozzles suggestions.
