Differences between 02 and 06 transmission
Discussion in 'General Subaru Discussion' started by predavore, Dec 28, 2008.
  1. predavore
    predavore Well-Known Member
    Southern 'Burbs
    What are the differences between an 02 and an 06 5 speed transmission?
    I have a spare 02 transmission/rear end that I had for th 02. Now that the 02 is gone, I'm wondering if I should hold onto the tranny or not for the 06.
    Experts... Please elaborate.
  2. Shibbs
    The gearing on the 02 is shorter, I know that much. I believe the final drive is different as well.
  3. predavore
    Southern 'Burbs
    Would it have to have the 02 clutch/flywheel assembly to work on an 06? Or does that all bolt in?
  4. Nuke
    Saint Paul
    06+ uses different style clutch
    3.7 final drive on the 06 also
  5. predavore
    Southern 'Burbs
    So that's a no? If so, I'm a gonna sell that thing. Need the room.
  6. Nuke
    Saint Paul
    you can sell it
  7. Colin
    Colin Well-Known Member
    Moorhead
    how much you want for the rear end? And is it tight?
  8. predavore
    Southern 'Burbs
    There is a thread for the sale.
  9. Threshld1
    Threshld1 Well-Known Member
    SLP
    06 has twin syncro 1st aswell. Being able to get into 1st going 30 FTW. And as Nuke stated it does use a push style clutch so the 02-05/Saabaru/BC turbo legacy pull style clutch will not work.
    I was under the impression it was a 3.54 final though... i could be wrong
  10. putz
    putz Well-Known Member
  11. Threshld1
    SLP
    Your correct, i was just gonna post the ratios from that site. Not that it helps with only 2 hits for the tranny code but the 06 is TY754VW7AA
    Ratios:
    [FONT=Arial,Helvetica]1st- 3.454, 2nd-1.947, 3rd- 1.366, 4th- 0.972[/FONT]
    [FONT=Arial,Helvetica]5th- 0.738, final 3.7[/FONT]
  12. putz
    it is a cool site!
