differential fluid
Discussion in 'Modifications And Maintenance' started by silver03, Jun 12, 2007.
  1. silver03
    MN Bugeye Mafia #300
    How to change the front on an 03 WRX with 4eat? Thanks
  2. bikerboy
    on the water looking for the sandbox
    Pull the drain plug and drain. Refill with new fluid. IIRC it's .85 quarts
  3. silver03
    differential
    drain and refill...that much i got.
  4. bikerboy
    So what is your question then?
  5. driftin240
    driftin240 Well-Known Member
    Out West
    There's a plug on the bottom of the front differential. On your's I believe it's a T70 torx bit. Otherwise if it's a normal hex hed bolt, it's a 21mm. It should be a bronze/gold color, and will sit right behind the front cross member.
    Pull the plug (make sure you don't lose the washer) and let it drain. Re-install plug and fill through the dipstick tube. The tube will be on the right (passenger) side of the tranny right behind the bell housing. You cant miss the bright yellow handle.
  6. silver03
    ^^thats what i was looking for. thanks
