Does TSX exhaust have a wb o2 bung?
Discussion in 'Off-Topic' started by Taras, Feb 25, 2008.
  1. Taras
    Taras BANNED
    Saint Paul, Minnesota
    Ok, i looked at my exhaust and cant seem to find an o2 bung on it. Does anyone know if its hidden somewhere? If not where should i get it tapped?
    Thanks, Taras
    BTW, i did search....
  2. Taras
    Taras BANNED
    wow i meant TXS not TSX. Its not acura exhaust.
  3. WRX1
    Over there
    No. I put mine in the catless pipe since it was the easiest to remove and I didn't have to mess with my jethot coatings.
  4. wall of tvs
    dream ftw
    It depends on if it's a v1 or v2 exhaust. The v2 has a bung on the downpipe for the addition of a wideband (and the v1 does not).
  5. Taras
    Taras BANNED
    I am not sure if it is a v1 or v2. So if i have hi-flow cat, should i remove it and get it tapped right before the cat?
  6. wall of tvs
    dream ftw
    The v2 will have it's bung towards the end of the downpipe down by where it mates with the cat/testpipe. IIRC, it would be on the passenger side of the pipe.
    I had Nathan weld a bung on my downpipe (I have a v1 stealthback).
  7. Taras
    Taras BANNED
    Yeah, i think i might have the exact same on as you. did you have to remove it to tap it?
  8. wall of tvs
    dream ftw
    No, Nathan was able to do it while it was still on the car.
  9. Taras
    Taras BANNED
    Any pics at all? So you did not have to take the exhaust apart at all?
  10. Bullwinkle
    Saint Paul
    You don't have to take it off the car. I got a bung welded to mine about 24" back of the turbo. Any local exhaust shop will do it for cheap.
  11. Taras
    Taras BANNED
    Cool, so whats the best place to put it in? I read that its better to have it further away from the turbo cause its too hot that might shorten the life of the sensor.
  12. Bullwinkle
    Saint Paul
    24"-36" back is acceptable. Also, at 3 or 9 O'Clock.
  13. Taras
    Taras BANNED
    cool, thanks.
  14. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    Yes, it must be between 9 and 3 so water can't collect on the sensor.
  15. Taras
    Taras BANNED
    that makes sense. So should i use the little bung holder that was provided with the kit?
  16. Nuke
    Saint Paul
    You could remove your rear o2 sensor and stick the wideband in there.
    It doesn't get all goofy like the 32bit ecu
  17. Taras
    Taras BANNED
    wouldn't i get a cel if i remove an o2 sensor? And how will the car run without it?
  18. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    so the hole further back for the "rear" o2 sensor isnt too far back from the turbo for a wideband?
  19. Taras
    Taras BANNED
    and mine is behind the cat so that is not so good.
  20. wrexinator03
    wrexinator03 Banana Cream
    your em should take care of the cel
  21. Nuke
    Saint Paul
    Too lazy to find on Nasioc about it, :laugh:
    But your car will run without it, plus you have the CEL deleted in your current map
  22. Taras
    Taras BANNED
    ahh, good point. So i can just unplug the rear o2 sensor? How about it being behind the cat?
  23. Bullwinkle
    Saint Paul
    The car will run fine, but you'll get lean readings on your WB02.
    Get a bung in the DP 24-36" back of the turbo and between 3-9 O'Clock.
    /thread.
  24. Taras
    Taras BANNED
    Thanks Nate!
  25. Taras
    Taras BANNED
    need a bung made the exhaust
    Got a wide band and I am pretty sure I dont have a hole for it. Need someone to tap my downpipe and weld a bung on it that I have. I would like to pay somewhere around 50 or so.
  26. Taras
    Taras BANNED
    wow writing just totally owns me.
  27. Dynapar
    Orono, MN
    What wideband did you get? some of them are able to wire into the ECU. so you could just use a stock mounting point.
  28. Hallywood
    Hallywood Well-Known Member
    Bloomington MN
    oh baby jesus
    Taras I hope your next topic isn't "I blew my engine...."
    Are you tuning your car or having someone do it for ya?
    If you can, bring your dp into any muffler shop, otherwise I have a buddy that would do it for you.
  29. Nuke
    Saint Paul
    Just go to some exhaust shop, there's one in Saint paul that I usually go to, gotta call them first though
  30. blackozone
    Dirrty Souf
    God dammit Taras, ****ing proofread!
  31. hella_sti
    hella_sti Well-Known Member
    anyone have a decoder ring to decephyer this??
  32. Hallywood
    Bloomington MN
    :laugh::laugh::laugh: so true
  33. blackozone
    Dirrty Souf
    In soviet Russia, writing owns you!!
  34. Taras
    Taras BANNED
    I am using openecu. So i do have to make a hole for the wb. I dont want to remove my downpipe. I have to drive places.
  35. AWDimprezaL
    Monticello.
    "My car has a CEL and its flashing" coming soon
  36. Bullwinkle
    Saint Paul
    OMG seriously, is this the second thread started about the same thing? Like I said in the other one...any exhaust shop will do it for cheap (like <$40). Just bring the tap that came with the WB.
  37. AWDimprezaL
    Monticello.
    word! its not new thread worthy expecially if old tunewinkle told you so
  38. Taras
    Taras BANNED
    gee, I am just asking for some help. I know I can bring it to a shop, but I thought maybe someone here can do it for cheaper. I would rather pay 20 to someone on the forum, than 40 to shop to pay their overhead.
  39. wall of tvs
    dream ftw
    Well you pretty much will have to bring it to a shop since you are going to need a hoist to lift the car. Otherwise you can remove your downpipe and have some random Joe weld the bung on.
  40. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    Needy and cheap is always a good combination.
  41. curly2k3
    Silent Hill, Jackass
    pretty sure you have already been given answers...but, we all know reading comprehension isn't your strong suit
  42. Taras
    Taras BANNED
    thanks found a good place for good money.
  43. w_o_t_boy
    w_o_t_boy Well-Known Member
    Seattle
    Gawd, this post is asking for it.
    "tap my downpipe", LOLz.
  44. idget
    falcon heights
    Fab King is gonna tap his bunghole and make him his Fab queen.
  45. Nuke
    Saint Paul
    :laugh:
    Taras is the king of owning himself
    :laugh:
