how do you take out the door panel....why i ask is becuz when i drive it makes a sqeeking noise fromt the inside.....
I believe theres screws behind some square cover. pop the cover open and unsrew them. I am not sure but I THINk so. I plan on opening it up in the winter b/c i can't unlock my doors with my Key
well the fartest i got was taking of 2 screw and this plastic pin....then the panel you have to slowly pull it and it'll pop out smoothly....but then it seem that near the handle part..there sumtin there like a screw thats keeping me from taking the panel off....any suggestion?
DANGER....DANGER....DANGER!!!! i took my door panel off some time ago to check wiring to my door speakers. and while my door has never been teh same since. i highly reccomend you dont take off the panel. since i have taken mine off i have broken the window crank, lost/broken 1/2 the plastic screws putting it back together, and have had wierd issues with my window. for instance when i would roll it down it would seem to work ok, but then at abotu 1/4 down the window would just fall all the way down. (scares the **** out of whoever is rollign it down). also i have had issues with my door panel randomly falling off when i try to open the door, which in turn will not allow the door to open from the outside, and must be forced form within. my two cents = dont do it
