DP CEL Fix???
Discussion in 'Modifications And Maintenance' started by bikerwriter, May 22, 2006.
  1. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    I've been running a TXS Stealthback on my '05 Saabaru for the past month and it finally threw the P0420 CEL for the rear O2.
    What CEL fixes have people used, mechanical, resistor, Pony Express, etc., and how well have they worked for you?
    I know there are forums on NASIOC, but I want an answer from somebody who has done the fix themselves...
  2. wall of tvs
    dream ftw
    I'm hoping that the openecu nerds will figure out the cel disable addresses soon.
    Also, there should be a new version of TunerPro coming out soon that will use the same XML definitions that the openecu nerds figured out.
  3. wall of tvs
    dream ftw
    But until then, you need to try doing the resistor fix first. :biggrin:
  4. Justin
    Justin Well-Known Member
    St. Paul, MN
    i have an extra mechanical fix laying around that i got from tim1223123uno's car.
  5. Ripcurl007
    Ripcurl007 New Member
    Rosemount
    try the perrin O2 simulator its $50 or something around that price and it works great
  6. bikerwriter
    St. Louis Park
    what price for your spare?
  7. Chin
    Chin Well-Known Member
    Savage
    Mechanical fix will not work.....been there, done that. It was fine for a couple hundred miles, then it would pop. I have the Pony Express MIL Eliminator now and it works. The only issue I have encountered is that it still triggers when it is raining out. I thought it was due to a wire being exposed, but I used shrink wrap with the 'goo' in it and I also globbed a lot of silicone around the ends after it triggered in the rain. No luck....
    However, it hasn't tripped this month, yet, even with all the rain. Go figure....
    YMMV
  8. DISCOPOPE
    DISCOPOPE Well-Known Member
    chin, if you still throw a cel w/one of the anti foulers try 2.
    if 2 throws a code you mightactually have a bad sensor. :O
  9. TSTRBOY2004
    I did the resistor mod on mine about 2 years ago and still havent popped a code..
    I will try to find the pic that shows how to do it.. takes like 30 mins to do pulling out the 02 and soldering in the resistor etc...
  10. DISCOPOPE
    with 04's and on the resistor fix is less effective.
  11. WRX1
    Over there
    Get a accessport and just turn it off (or have me turn it off). I have done a couple with the anti-fouler (used 2 of them), and have never had any problems.
  12. joegengsta
    joegengsta BANNED
    use the spark plug antifouler trick
  13. bikerwriter
    St. Louis Park
    Are they the 18mm anti-foulers?
  14. joegengsta
    joegengsta BANNED
    i believe so, 99.9% sure.. search on nasioc to confirm
  15. Chin
    Savage
    Tried 2 of them to start with.....the sensor was new, as well.... Try again. ;)
    The Pony Express fix is not that expensive, do it right the first time.
  16. Zola
    Zola Well-Known Member
    St Louis Park
    The Pony Express fix is about $1.50 in parts from Radio Shack.
    NOTE: The above is for a 2002-03, the required parts may very well be different for 2004+. YMMV. I know the original poster has a 2005 but this is just to illustrate the basic concept of the electrical fix. If the mechanical fix works, then that would be my preferred route.
  17. Threshld1
    Threshld1 Well-Known Member
    SLP
    that looks like a basic low pass signal filter to me
  18. TSTRBOY2004
    thanks... thats the one I used to do mine.. havent had a problem since that in over 2 yrs
  19. bikerwriter
    St. Louis Park
    I actually used the ECU tuner Enginuity and changed my CEL values for the P0420 code to disable the CEL. The CEL hasn't come back yet.
    Man, I love my Tactrix cable and free software!
  20. wall of tvs
    dream ftw
    You should also love my hyper-intelligence for showing you how to use all that crap. :p
