driveshaft
Discussion in 'Want To Buy : Cars/Parts' started by Scott, Nov 14, 2014.
  1. Scott
    Scott Well-Known Member
    I may need a new used drive shaft center bearing. That car started making some weird sounds last night while pressing the loud peddle. I will explore a bit more tomorrow.
    Just wandering if there are any on someones garage shelf's.
    02 wrx sedan
  2. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    I had this happen to my OBS once. I was hearing a loud whirring for a while. Then a loud clicking under throttle. After a lot of bs, the front joint of the driveshaft was cracked and the little roller bearings had fallen out. Found one at a local junkyard and put it in.
  3. xluben
    If you do end up needing a driveshaft, I might have one. I don't remember if I threw it out or not.
  4. Terry Ammerman
    I do have one.
  5. Chux
    FYI, they're different length if the car is an auto or manual trans
    Terry Ammerman likes this.
  6. Fastsuby
    Fastsuby Member
    I have one from a 06 manual wrx if you need
  7. Scott
    As of now the ujoints and center bearing seems OK. Now I have to start searching elsewhere.
  8. Nhibbs
    Nhibbs Well-Known Member
    Man I just threw one of these out when I moved.
