driving on a blown head gasket
Discussion in 'Modifications And Maintenance' started by SubieDave, Mar 14, 2008.
  1. SubieDave
    SubieDave Well-Known Member
    I keep telling my brothers parents to stop driving the car. They think that since it can and will start, that it is ok to drive. :ugh: So I want to scare them and tell them what can actually happen to the car if they drive it.
    So I want to know what can or will happen to a car if it is driven on with a blown head gasket?
  2. StatGSR
    StatGSR Well-Known Member
    Heads can warp, and bearings can get boned if there is coolant in the oil.
  3. SubieDave
    There is oil in the coolant, but no coolant in the oil as of yet
  4. SubieDave
    Anyone? What else can happen?
  5. Flat4
    Flat4 Well-Known Member
    wouldnt that be your parents
  6. curly2k3
    ask Luke what happens. also, Dave could be a step brother or something...insensitive prick :)
  7. SubieDave
    Negative
  8. curly2k3
    you can warp the crap out of the head for one, and in some cases you can do damage to the block as well
  9. HoLsTeR
    HoLsTeR Well-Known Member
    does the car smoke when its started?
  10. dman
    dman New Member
    It'll overheat, engine will crack from temperature/fuel lines will melt/rip from temperature and it will catch fire. Scary enough?
  11. SubieDave
    ^That pretty much does it!
    Not sure about the smoke. Again, it's not me driving it. I'm in EP and the car is in WBL. What does the smoke mean?
  12. HoLsTeR
    from what ive known. blown head gaskets lead to smoke pooring from the exhaust
  13. Chux
    it depends where the leak is. if the coolant is leaking into the combustion chamber in quantity, then it'll burn off, and cause white smoke.
    but, you can also have HG failure that will just cause the coolant and oil to become one. also, if there's oil in the coolant, there's coolant in the oil. I don't think it's really possible to have a one-way leak. especially considering the fact that the coolant is pressurized.
    if you're just loosing coolant into the combustion chamber, it really doesn't hurt it too much as long as you don't let it run low and overheat.
    but if the fluids are mixing, different story (unless you change the fluids every few hundred miles). Coolant makes terrible lubricant, and oil makes terrible coolant. they're really not interchangeable.
  14. nm+
    nm+ Professional Hypocrite
    This fact took Porsche forever to figure out. :biggrin:
  15. Vorgto
    Vorgto BANNED
    HEHE look at my MR2
    Warped block/head...
    Other things overheated/melted.
    VERY EXPENSIVE!
