Okay, Shane and I found threads on an 06. BUT, not the same as mine. Says to cut or remove a green and yellow wire from this relay. WELL, here's pics. Which one to remove? http://i14.photobucket.com/albums/a339/shibbypoopalot/PICT0023s.jpg http://i14.photobucket.com/albums/a339/shibbypoopalot/PICT0024s.jpg
Why not just unplug the relay? That relay has two power outputs. Does the other curcit power something important?
it's my understanding that it's an "OR" relay... one output goes to the diode and resistor for DRLs and the other goes to the full power headlights. i'll link to discussions on nasioc tomorrow. sleep needed tonight and southpark is on.
Just unplugged it on the wife's car. Passanger side above the wheel well. Did they change it? Mike showed that to me and it was the same way for many years of the Suby's.
Yah... i know about the wheel well disconnect. i did that to my car. that DRL module doesn't exist in the 07, or it's been moved somewhere else.
Here's some links: http://forums.nasioc.com/forums/showthread.php?t=1109279 (with written how too) http://www.iwsti.com/forums/showthread.php?t=64791 The issue is that the description seems to be Dependant on the fact that the car is an STI with HIDs. the wiring is different, at least color wise.
