DSM guys
Discussion in 'Off-Topic' started by silver03, Nov 11, 2011.
  1. silver03
    MN Bugeye Mafia #300
    Looking at buying an unmolested lower mileage gen 1 eagle talon tsi. Anything in particular to pay attention to on a pre purchase inspection? thanks
  2. chris02rex
    chris02rex Well-Known Member
    Alexandria, MN
    Leaks, Underbody rust, and possibly a car fax. Heard of some people swapping clusters for lower mileage ones.
  3. silver03
    I know this particular owner well and they have owned the car for a number of years. Good advice nonetheless, thanks.
  4. AWDimprezaL
    Monticello.
    Things you need to have while owning a DSM
    Therapist
    Storage space for car to sit when it breaks
    swear jar
    punching bag
    PATIENCE!
    97_Impreza likes this.
  5. Deride
    Make sure you get a set of jackstands with the deal.
  6. silver03
    Well, I am back from looking at the car. What I found: 105k mile 2 owner car. Car is an automatic. No mods. Needs cv axle drivers front, oil leak from valve cover gasket and something leaking oil around the turbo. runs and drives fine with a fair degree of wheel vibration at highway speed. Also paint is fairly faded with the hood and quarter panel needing a respray. Mirror has a chunk out of it, both rear hatch struts are shot. But...zero rust, and the body is straight as can be. Lets say tires and brakes are good. $1500?
  7. jhoff13100
    jhoff13100 Member
    well if its a 6 bolt i say go for it even though its auto.
  8. dustin8511
    dustin8511 Member
    Two home's - Detroit Lakes/Fargo
    What year? Youd deff want the 6 bolt motor (no crank walk). I believe the 91's and 92's came with the 6 bolt, and 93+ was the 7 bolt. If the basic drive line seems solid, then it's worth the $1500. After purchase, I would deff change the timing blet, water pump, and tensioners. Timing belts are notorious for failing on dsm's, however I'm sure you know that. Good luck!
