e brake light on
Discussion in 'Modifications And Maintenance' started by asiandude, Nov 2, 2005.
  1. asiandude
    asiandude Well-Known Member
    my e brake light is always on know. what could be the problem?
  2. AWDimprezaL
    Monticello.
    its not just your e brake light, its everything to do with your brakes, check your fluid
  3. Natural2JZ
    Natural2JZ Well-Known Member
    Minneapolis, MN
    brake fluid
  4. 02blubru
    Norwood Young America
    What does that have to do with brake lights?
  5. asiandude
    fluid full
  6. Klesk
    Klesk Well-Known Member
    Does it do it when its cold?
  7. AWDimprezaL
    Monticello.
    oh no a kid that thinks MNsubaru "is stupid" doesnt like me.....anyways definatly take it in...it could be bad, or it could be just the sensor inside the resevior.
  8. TSTRBOY2004
    or your switch ont he e-brake might be faulty or maybe you didnt put the e-brake all teh way down??
  9. asiandude
    the e brake is all the way down, it started coming on and off and then one day it just wouldnt go away..
  10. AWDimprezaL
    Monticello.
    are you sure your brake fluid is full? it sounds like its low, then it sloshes around
  11. asiandude
    thanks brake fluid was low.....but i just filled it not to long ago
  12. AWDimprezaL
    Monticello.
    hard braking will wear down your pads which makes a place for the fluid to go, thus making the resivior low. glad you found the problem.
