E85/E70?
Discussion in 'General Subaru Discussion' started by WLGT, Dec 5, 2012.
  1. WLGT
    WLGT Well-Known Member
    Do you need two different tunes or will one be fine as long as it was tuned correctly for both.
  2. BroCo
    BroCo Moderator Staff Member
    E70?
  3. Mr.Tran
    Mr.Tran Well-Known Member
    I assume he's referring to winter blend or pumps that say "contains atleast 70% ethanol"
  4. SurlyOldManMN
    That's a question for your tuner. If they put you on the bleeding edge of the target fuel grade you're going to have problems when you step down. If you were more conservative then you probably have no worries. You could ask the same question of 93 vs 92.
    BugIedIzzy likes this.
  5. Back Road Runner
    There are folks that do both: one tune that works reasonable across the spectrum or two (or 3) tunes that are preset for each change. I believe E85 goes through 3 steps in grade between summer and winter to retain starting and driveability.
    There are tuners who have played with E85 and people who have driven on the stuff year round, so it's perfectly doable if you want. I think you may prefer more than one map that you can switch between as needed, but I know some drive on catch-all tunes that work year round, likely with side-effects to some degree.
