ej20tt
Discussion in 'For Sale : Car Parts' started by B13sr20, Dec 31, 2008.
  1. B13sr20
    B13sr20 New Member
  2. AWDimprezaL
    WOW, nice find.
  3. 05cgmsti
    05cgmsti Well-Known Member
    My forester could be alot more fun with this. Too bad I spent my money on presents. Motor+trans+ecu+turbos/ic+everything else is a steal for 1300. :*(
  4. readymix
    Yes, this is definately a steal! Someone should snatch this up
  5. qstarin
    qstarin Well-Known Member
    Interesting.
  6. stiv5
    stiv5 Well-Known Member
    I saw that a last week but I did a research on the motor and found out that it would be difficult to swap and lwould need lots of work to be done to make it fit right. It's a good deal though and local.
  7. qstarin
    Unless you go single turbo on it, IIRC? Thought all the trouble fitting was because of the two turbos and associated exhaust stuff. Or you could do RHD, too, again IIRC? I think I remember that was easier than fitting it in a LHD setup! lol
  8. 9blackmax6
    sooo sexy
  9. TSTRBOY2004
    do eeeeeeeeeeeet
  10. Chux
    interesting. looks like a jhot swap (looks exactly like the pictures they post on their ebay ads). would probably save a few hundred on shipping, but it's really not that terribly low for a tt. I forget, '97 is near the cutoff, I wonder if that's an EJ20H or R.
    in any case, would still be cheaper in the long run to start with a single turbo setup, unless you're putting it in a buggy or something.
  11. speedyham
    speedyham Well-Known Member
    You'd still need the whole chassis wiring harness, unless you want to do a lot of splicing wires. It doesn't look like that is part of the setup. Still not a bad deal for $1300.
  12. qstarin
    Anyone know what the final drive is on the tranny, out of curiosity?
  13. curly2k3
    you will need to do a RHD swap unless you are redoing all the turbo set up
  14. 05cgmsti
    yeah i read a nasioc build journal for a ej20tt swap into a usdm legacy. sounds like a royal PITA to get it to work with a lhd car. I didn't realize these were so cheap compared to most other subaru motor setups though, the headaches must be accounted for in the price lol
