EJ257 Engine
Discussion in 'General Subaru Discussion' started by scoobypwnz201, Jul 22, 2008.
  1. scoobypwnz201
    Becker MN
    so i got a question iv been searching around teh internetz for one of those 2008 STI engines (i assume they are EJ257's?) but i can't seem to find any anywhere (searched over 15 websites with just a skeletal shortblock) do you guys know (i bet they do but still) if they sell any of the 08 + sti engines yet?
  2. AWDimprezaL
    Monticello.
    you looking for used?
  3. scoobypwnz201
    Becker MN
    got prices for both used and new?
  4. AWDimprezaL
    Monticello.
    well we dont sell entire engines, only shortblocks and bare heads
  5. scoobypwnz201
    Becker MN
    damn :\ im trying to get my hands on a fully functional 08+ sti engine IF i can its just a possibility...im starting to draw out some ideas finally for my car
  6. AWDimprezaL
    Monticello.
    they can ship that you know...bunway airlines is very competitive
  7. Aegis
    Female
    サイレントヒル
    What are these ideas for your car? Are you going to build a new car from scratch, starting with the engine? :laugh:
    No, I am just kidding ... but really, what are your plans?
  8. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    whats different on the new 08?
  9. Dream
    south
    omg avcs on intake and exhaust side
  10. AWDimprezaL
    Monticello.
    larger capacity oil pump
  11. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    all of which you can add on to any 04-07. anything elce?
  12. scoobypwnz201
    Becker MN
    well the IDEA so far is that i want to buy a hobby car that can do well on the dirt as well as on the street i want somewhat upwards of about 400 WHP
    NOTE: that this is my dream car for some they want Lamborghinis or porches or some sort of luxury sport im a simple man..i love the subaru performance the ability to create a custom car just appeals to me more than buying something for 100k that i didn't put any work into myself
    performance
    1. once i get this job im going to start trolling around for a 00-01 2.5 RS (im totally obsessed with the model for some reason)
    its going to have JDM parts (i understand that its probably a dumb expensive idea but meh its a hobby car)
    2. after buying the car i shall start with the performance parts starting with the access port (for me money isnt really a big deal because i don't have to pay my college loans till mid 09 and i live with my rents with my pops whos a subaru enthusiast as well as an ex semi-pro rally racer) im thinking about the cobb 2.0 AP
    3. then i shall buy the engine im looking at either an 08+ JDM or USDM engine (hopefully the JDM but i don't care they are both fairly good engines either way)
    4. after buying the engine im going to get a 6 speed manual trans (they are designed better than the 5 speeds)with a lightweight flywheel and a multi layer clutch (so it can handle 400 HP)
    5. not sure about the turbo yet it will either come from garret or blouch (blouch are fairly good turbos)
    6. ill get a suspension from rallispec probably the 55-51 rally suspension with hydraulic bump top system
    as for the rest im still in the process
    the Look
    1.well for the exterior of the car i want a WR blue paint job
    2.i want the yellow subaru rally logos on the side
    3.HIDS
    for the Interior
    4. i want a black and blue color match
    5. sparco seats
    6. sparco pedals
    7. the limited edition subaru rally sport 6speed shifter
    there will be more :D
    Edit: and i do realize that it might be hard to get 400whp but im totally open to ideas and i have been looking around on nabisco here and iclub im really determined to do this
  13. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    i still don't get why you want to waste $$ on new 08 stuff? 400whp is easier then you think to get to on any of the year sti's. hell you can buy forester xt crate motors for around 3k and you would be changing all the things that make it different then a sti to get to 400whp anyway. and ap is a waste of money because anything you cant do with open ecu you would have to go to a stand alone to get anyway.
  14. scoobypwnz201
    Becker MN
    i suppose you could get the same results from a different engine than from an 08 its because its a newer engine less miles..
    however isn't the new engine more efficient?
  15. tux121
    tux121 Well-Known Member
    Champlin
    More torque with the Dual AVCS.....better spool.....
  16. scoobypwnz201
    Becker MN
    im reading up on the ECU i like open source i should have seen somthing like this
  17. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    just build your set up to the way you want the car to act and what you want out of it. you can get a turbo that makes 400whp to spool before 3500rpm if you ave the right parts. no need to waste the $$ like i said. and you can always buy the avcs sensors, cams, and came gears and run avcs on a aux map on any sti head if you think you have to have it.
  18. scoobypwnz201
    Becker MN
    i will definitely look into this thank you for your input :)
    i just didn't know you could create a dual AVCS system on any sti
  19. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    depending on when your sti was made, some (mine) got the heads that have the cam sensor boss on them. it just needs to be drilled out.
  20. scoobypwnz201
    Becker MN
    this is why i like this community..they don't bash you hardcore they actually have good criticisms. i can't wait to get this going..
    i just want this god damn job so bad lmao
  21. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    Ha dream schooling fobia on a tech question. Never thought I would see the day.:laugh:
  22. readymix
    Eloh, El
    Buying an 08 STi motor would be a total waste. Like Fobia said, a crate Forester motor is around 3k ish. And while AVCS intake and exhaust is neat and all, the gains on it might not be worth the effort.
    There are tons of clutches out there that will handle 400whp. 400whp on a 257 isn't really hard to attain these days.
    And OpenECU is cool, but keep in mind that to run different fuels you will need to have a laptop that you carry around with you to switch the maps. The AP is nice, but from experience, you'd be better off going standalone for something like this.
  23. T-REX5000
    T-REX5000 Well-Known Member
    St Louis Park, MN...uptown really
    dont forget bigger brakes too :)
  24. scoobypwnz201
    Becker MN
    OH RIGHT i forgot to mention the brembo break kit!
  25. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    yes. he knows the 08 stuff. i have no need to really care about them to look into them.
