These are the '98 Legacy GT heads that came off my motor. I just pulled them off the block yesterday and they look great! No burnt oil inside the head, journals look good and all the cams are in great condition. No built up gunk in the intake ports (I didn't have to clean them, they were like that when I pulled everything apart) either. You could very well clean the old gasket up, and throw them on. The car never overheated. and there were NO leaks. I made sure to use the correct loosening sequence. **They did NOT fall victim to HG failure** It will come with the following parts. -Heads -Intake manifold -Throttle body (It MIGHT need a new TPS* see below) -Injectors (Stock) -Coil pack -Plug wires -MAF w/airbox and intake tube *I'm not sure if the TPS is bad, or if it was the low compression motor paired with the stock ECU. I do have a video of the car running with everything for sale. I'll try to get that up tonight. If not I can send it to whoever requests one. If you want to come look at them, I can bring them to work and you can stop by, or I can meet you after I get off. Starting price $600/obo Trades I would be interested in are: -Top feed TGV deletes -1600cc top feed injectors
I know where at least 3 of the 4 are and know 3 of the 4 are in good shape not sure on the 4th one. My parents are going to find them and bring them down this weekend.
I WILL sell items separately! There has been more interest that way! Get these out of my garage and on to YOUR car!!!
I'd let the heads go for $400. They are currently pending. John, you are next in line. I'll keep you posted.
Heads are SOLD! I still have the EJ25D intake manifold with injectors and fuel rail. I'll get it go real cheap! Just get it out of my garage!
Those heads were rebuilt when I put them on the engine. Also someone take the intake Mani and fuel set up. It is all POWDER COATED not painted. (Valve covers, intake mani, throttle body, fuel rails, fuel lines)
