engine management
Discussion in 'General Subaru Discussion' started by subiedan, Nov 7, 2006.
  1. subiedan
    subiedan New Member
    Rogers, MN
    does anyone know if there is an engine management system available for my 97' legacy gt 2.5 dohc?
  2. RallyNavvie
    RallyNavvie Well-Known Member
    Dallas
    Of course there is. How much work do you want to put into it?
  3. AWDimprezaL
    Monticello.
    i find that funny...because im using your computer as my managment in my current n/a turbo 2.2 setup...working perfectly
  4. Dynapar
    Orono, MN
    you can go with a piggy back or a standalone. they both have pros and cons.
    Standalone you are looking at:
    PowerFC
    Hydra
    Link
    Piggyback:
    PerfectPower SMT6
    Greddy Emanage
    oh and i would avoid the SAFC/SAFCII IMO they are junk.
  5. piddster
    Boostonia
    Haltec
    AEM
    Electromotive
    MoTeC
    As far as wire-ins go, but the price goes up with each. I will say, motec = t3h hawtn3ss. I went for the Link cause I think it has the best value for the money for an older motor. It all depends on your needs/goals and how much flexibility you want down the road. I'll be changing heads, injectors, cams, pistons, turbo, among other crap later so I need the flexibility of a standalone with plenty of availible inputs/outputs.
    What are you doing where you'd need EM?
  6. RallyNavvie
    Dallas
    Meh, E6X 4TW
    The new Haltech ECU finally has a Windows interface and more PWM/digital inputs/outputs to play with. And all the exhaustive features it had before. But how much work do you want to put into it?
  7. subiedan
    subiedan New Member
    Rogers, MN
    thanks for the input everyone, my first step is to get the money i need, hten ill decide which one to go with.
