F/S 2005 OPB WRX
Discussion in 'FS: Cars, Motorcycles, Boats' started by Ninja 4 Life, Jun 7, 2015.
  1. Ninja 4 Life
    St. Paul
    Up for sale is a 2005 OBP Impreza WRX. I am the second owner of this car, I bought it from Walser Subaru back in 2009. It has been a very reliable daily driver these past 5 and a half years and sad to see her go. I have been running Subaru 5w30 synthetic oil since the car hit 85,000.
    Mileage- 144,xxx
    Asking- $8,600 or best offer
    -Timing belt, water pump and pulleys done at 110,000 with Gates kit.
    -New spark plugs around 110,000 miles.
    -New valve cover gasket around 115,000 miles.
    -New radiator around 120,000 miles.
    I do have a list of other maintenance records for any possible buyer.
    List of Mods:
    -Cobb stage 2 tune from Accessport
    -Megan Racing cat-less down pipe
    -07 STi cat back
    -Cobb heat shield
    -Karboy short throw shifter (stock included)
    -Perrin Fat shift knob
    -Eibach 22mm front and rear sway bars (stock bars included)
    -Eibach rear end links (stock included)
    -Perrin front endlinks (stock included)
    -Perrin stout mounts
    -eBay front and rear strut tower braces
    -Perrin drop in foam air filter (x2, also have the recharge kit)
    -Perrin Afta tube (stock included)
    -Mach V SS brake lines
    -Grimmspeed gold oil cap (stock included)
    -JVC CD player with USB and AUX ports
    -JDM red hazard switch
    -07 WRX 17 inch wheels with Dunlop Direzza DZ101 225x45 17
    I also have a box of random parts I will throw in, along with a set of Yokohama W. drive 215x45 17 tires as well.
    Cons:
    -There is an oil leak on the plate that the oil filter attaches to. I was told it is about $160 for Subaru to fix this.
    -The A/C works, it just had a leak some where in a line. I had dye run through with the last recharge, but was not able to fix it at the time.
    -There is a spot on the front bumper after some one back into the car in a parking lot. I was able to pop it in where it was cracked, but you can still see the spot. See picture below.
  2. bmc07wrx
    bmc07wrx Active Member
    Maple Grove
    This thing still for sale?
  3. Ninja 4 Life
    St. Paul
    Yes it is.
  4. Ninja 4 Life
    St. Paul
    Bump for $8,600. Mods please change description price.
  5. tangledupinblu
    MNBugeyeMafia#001
    You got it!
  6. Ninja 4 Life
    St. Paul
    Oil changed and oil leak fixed yesterday bump.
  7. Ninja 4 Life
    St. Paul
    Mods please lock it up, I've decided to keep it.
