F/S Audiobahn ALUM12J 12" sub new
Discussion in 'For Sale : Car Parts' started by ikpthegame, Apr 29, 2011.
  1. ikpthegame
    ikpthegame Well-Known Member
    This is brand new never used. I only opened it to take pics, and has just been sitting around since I went with something else. You can text me at 651-206-7663, keep in mind I work over nights.
    lets start at $200 obo
    DUAL 6-OHM CONFIGURATION: Accommodating the rising trend of triple-subwoofer applications, Audiobahn’s Sound Q subwoofers come in dual 6-ohm configurations.
    SURROUND: To lengthen the life of the woofer and to ensure continued enjoyment, this series’ surround is made from EPDM rubber, a denser yet flexible material that is designed to hold its shape over time. It is made to withstand weather conditions such as high and low temperatures.
    MULTI-CONNECT LUG LOCK TERMINALS: Audiobahn’s patented Multi-Connect Lug Lock Terminals offer increased versatility in wiring multiple subwoofers to an amplifier or to another voice coil. Multi-connect terminals allow you to use single wire connections in each terminal rather than combining multiple wires into one terminal. This feature allows you to use a full 8-gauge wire in each terminal.
    Features
    • Phat 1.75” EPDM Rubber Surround • Spun Aluminum Cone • Dual 6 Ohm Voice Coil• Multi-connect Lug Lock Terminals
    Magnet Weight: 120 oz.
    Freq. Response: 18 Hz - 500 Hz
    Efficiency: 94.4 dB
    Voice Coil: 3" Dual 6 Ohm
    Operation: 3 or 12 Ohm
    Mounting: 5 5/8"
    Hole Cut Out: 11"
    Outer Diameter: 12 3/4"
    Spun Aluminum Cone
  2. ikpthegame
    since i dont see a edit button and i forgot to put in a price, lets start at $200
  3. ikpthegame
    200 or best offer, need to fix some stuff.
