F.S. axxis ultamate front brake pads
Discussion in 'For Sale : Car Parts' started by ruberdukwrx, Apr 18, 2008.
  1. ruberdukwrx
    ruberdukwrx Well-Known Member
    I have a new set of axxis ultamate pads for the new style calipers $50
  2. Nuke
    new style caliper?
    the newer 02 or the 06?
  3. ruberdukwrx
    some place in the middle of 02 and 03 they made the caliper so that the brake pads used are wider on the part you slide into the caliper2002-2003 D721/D770 Subaru WRX Performance Brake Pads
    Axxis - Hawk
    There are multiple brake caliper combinations for the 2003 WRX model year. The only way to ensure you are buying the right pads for your car is to measure the pads already on the car and use the picture on the left as a guideline.
    The pads on this page are for 2002-2003 WRXs with the same pad dimensions as the image to the left (D721 front and D770 rear pads). If your pads are different from the diagram on this page, click here to find the appropriate part for your vehicle.
    Shipping costs are calculated upon checkout
    FITMENT: All 2002 WRX models and 2003 WRX models with the D721/D770 caliper combination.
    NOTE: If you have a 2003 WRX, you need to measure the dimensions of your stock brake pads to determine which calipers you have. Use the diagram above as a reference. Please call before you order if you have any questions.
