F.S. tein coilovers
Discussion in 'For Sale : Car Parts' started by ruberdukwrx, Jul 15, 2009.
  1. ruberdukwrx
    ruberdukwrx Well-Known Member
    the following parts are F.S.
    tein basic coilovers $500 and stock struts and springs
    exedy twindisc clutch with 10 miles on it $1300
    perrin 25mm front and rear sway bars and end links $400
    greddy front and rear strut tower brace $200
    perrin rotated mount turbo kit includes uppipe ,downpipe ,dump tube,tial44mm waste gate garrett t67 turbo and cold air intake $2500
    aem ems with 5 bar map sensor and inlet air temp sensor $1200 and oem ecu
    set of ej20 heads with bc valve springs and retainers and stage 3 crower 272 cams $900
    jdm spec c intake manifold $500
    fuel injector clinic 1200cc injectors $300
    set of 4 rota torque black with red lip with falken azena 245/40/18 tired $900
    perrin fmic with blow through maf tube $1100
    I will take pics of whatever you are interested in but you will have to just ask me since most of the stuff is still on the car but if you need pics I will be more than happy to get them as soon as I can !
    here are a couple pics so u can see the fmic and the intake
  2. 2.5RS
    2.5RS Well-Known Member
    pic of the tien coilover..??
  3. ruberdukwrx
    I will post some pics tonight when I get home or tomarrow! Thanks for asking!
  4. mnstilynwrx
    mnstilynwrx Well-Known Member
    pics of the FMIC please
  5. curly2k3
    high or low on the injectors? assuming they are side mounts as well?
  6. PhilSine
    PhilSine Well-Known Member
    pic of the intake please
  7. ruberdukwrx
    they are high impedence injectors and are the side clip like dsm I will post pics of the other stuff today when I get home from work but I am not going to remove anything from the car till I have a serious buyer but you will be able to at least see the stuff thanks
  8. WrxMiller
    WrxMiller Well-Known Member
    how many miles do the coilovers have on them?
  9. ruberdukwrx
    Probally like 2000
  10. blackzpremacy
    blackzpremacy Well-Known Member
    what kind of numbers did you put down with the turbo/fuel set up?
  11. ruberdukwrx
    I made 527whp and 430 tourque
  12. bobafett04wrx
    bobafett04wrx New Member
    On a 2.0 and stock tranny?
  13. carl
    what trans is the exedy for?
  14. ruberdukwrx
    I had it on a 2.5 block with 5 speed mt
  15. ruberdukwrx
    would consider trading some stuff for atv or dirt bike also!
  16. Wakaba
    Wakaba BANNED
    How many miles on the Tein's, and when was the last time they were rebuilt.
  17. readymix
    Do the injectors come with the side clips?
  18. ruberdukwrx
    yes the injectors would come with side clips and the coilovers have a couple thousand miles on them never rebuilt
