Feeler '05 STi 6M/T Tranny :-)
Discussion in 'For Sale : Car Parts' started by driftin240, Jun 13, 2007.
  1. driftin240
    driftin240 Well-Known Member
    I have a 2005 STi tranny that i'm considering selling because of the hassle of putting it into my car. The downside to the tranny is that it's more than likely gonna need a center differential which is quite a pretty penny. I'm not 100% sure that it needs it, but it was binding pretty badly. The fluid was clean, with no metal debris. Came out at 27k miles.
  2. readymix
    What if I wanted to do away with the center diff altogether and block it off and run it in a mid-engine RWD configuration?
  3. tangledupinblu
    yes! readymix's 'crazyslidwayzrearwh33ldriftorz'...car
    500hp minimum please!;)
  4. readymix
    I'd need someone that can weld really well, and someone that has time and some engineering experience to pull it off. And more than likely someone that has a totaled wrx or turbo'd RS with a good turbo crossmember they were willing to part with, along with alot of other stuff......
    ....so essentially, not gonna happen. But I can dream, right? Oh to win the lottery.
  5. tangledupinblu
    hahaha...just saw a wrecked and completly stripped wrx in Fridley if you would like mo info.
    But dreams I'm sure will do for now. :roll:
  6. driftin240
    Yur crazy Jason. At first I thought you were going to get rid of the PPG setup and I was gonna have to kill you.
    I can't weld aluminum that good, and I haven't done it in a while either. It would be funny if the block plate from a FWD 5-spd would fit on there. Then there wouldn't be any need for welding.
  7. chokin
    chokin Well-Known Member
    Taras' wrx would be ur best choice
  8. readymix
    Here's teh deal. I haven't the money to do a project like that right now. If I did, I'd be all over something like that. I've thought alot of it out in my head though. It would involve cutting the rear passenger compartment area floorboard and seating support out completely and welding in the turbo crossmember. Then after fitting the motor in there, you'd need to cut the rear floor out to accomodate the tranny. A new crossmember for the tranny would be needed. Not sure if you could just modify a rear AWD differential brace or not. I would assume that as long as the transmission sat near the same plane as it would if mounted normally, then the axles would meet up with the rear hubs just fine since the rear wheel base should be about the same as the front. Speedometer and such shouldn't change since we'd keep the same wheel dimensions and tire sizes. Although I'd probably run a 11" wide by 17" diameter wheel in the rear for super JDM #1 dorifto mega sensastion action. The easier part is figuring out how to mount an intercooler and radiator. This would likely be best done by welding the rear doors shut, or at least louvering them for ventilation and mounting the intercooler and radiator in one of the rear doors. Or you could run some thick hightemp hose to the front for the radiator and roof mount the intercooler...both options would be final thoughts though. Getting the engine in and the tranny in would be the hard part. Then sealing everything up in the car. Some kind of trick metal cover with hinges would be sweet. Eitherway, I don't see how it would be impossible. That is the way the Saker is configured, EJXX mid mounted with a tranny modded for FWD but connected to the rear wheels instead. All the other stuff is details. And just think of how awesome the sounds would be if they were IN the car....glorious noise!
  9. Dynapar
    This would be quite the amazing plan. FYI: Fuji has a turbo x-member for sale from a Tleg.
    Just out of curiousity what are you looking to get for this tranny? I know that there are a few places in japan (tanannebebane? auto services) which sell replacement center diffs for both 5spd and 6spd which will allow all of the power generated to get transfered to the rear wheels. This tranny might be the perfect start to a RWD subie. although from what I have heard from the Team Orange cars the standard subaru diffs dont hold up well to 300hp going striaght to the rear end...
  10. readymix
    Yes, but I don't want to run it to a rear diff. The transmission would essentially BE the rear diff. The engine would be mounted behind the front seats.
  11. wall of tvs
    hmmmmm....so what type of $$$ are we talking about here?
  12. readymix
    For the tranny or for the Impreza MR.
  13. wall of tvs
    to put the whole WORKING shebang into oh say........an '06 WRX
  14. Justin
    Justin Well-Known Member
    lets chat tomorrow at the shop about this
  15. Zombie
    Zombie Well-Known Member
    I am also interested. PM me a price!
  16. driftin240
    I think the price is gonna be in the $500-$600 range. Not sure though.
  17. wall of tvs
    hmmmm..........very tempting.
  18. Nuke
    hm.........................
  19. phi11
    things that make you go, hm....................
  20. Dream
    500-600 for a tranny is a steal, somebody snag this my god!
  21. ShortytheFirefighter
    The part number for the center diff is 38913AA160 and the club price (including tax) is 2092.74. You're still ahead of the usual going price I see which is around 3k.
  22. Justin
    yeah i'm working on it
    damn...i was hoping <1000. maybe used some where
  23. readymix
    Yeah, good luck finding a used STi 6 speed center differential in a usable condition.
  24. Sogonerg
    Sogonerg Anteater
    snagged ;)
    Thanks Brian...
  25. Nuke
    geez ray
  26. Sogonerg
    Sogonerg Anteater
    hmmm..yea Nuke!?!
  27. w_o_t_boy
    w_o_t_boy Well-Known Member
    Just build a Porsche 914 subie swap if you want mid-engined wackiness.
  28. readymix
    That would require me to buy a 914...which I don't have the scratch for right now. But I would love to do a 914 Suby swap.
  29. Nuke
    Just hating on you
  30. Sogonerg
    Sogonerg Anteater
    ^is there a difference on how u treat me now? haha
  31. Nuke
    See, before, it's playa hatin' y0
    Now it's straight hating!!!
    Damn, only if I had the $mulah$...i hate my tranny
  32. Sogonerg
    Sogonerg Anteater
    u can have it for $3k ;) lol actually...after everything (upgrades)...$6800 w/o shipping yet :biggrin:
  33. Dream
    make sure you put the 07 gears in that thing
  34. readymix
    I think Ray is just going to rest it on jackstands in the garage.
  35. AWDimprezaL
    why 6800 in upgrades to a tranny YOU ray couldnt possibly break STOCK
  36. Justin
    HAHAHA
  37. Sogonerg
    Sogonerg Anteater
    Keeps the miles low...lol
  38. driftin240
    Incase you all that PM'd me don't know, the trans in now sold to Ray. It did get shipped today Ray, but I have to get the tracking number from the shipper tomorrow.
  39. Sogonerg
    Sogonerg Anteater
    Thanks Brian...w00t!
  40. w_o_t_boy
  41. Sogonerg
    Sogonerg Anteater
    ^oh that's swell..:roll:
