Feeler thread: GB Frozen Rotors
Discussion in 'For Sale : Car Parts' started by Underhill, Aug 9, 2007.
  1. Underhill
    Underhill New Member
    I don't know if someone else on here does these or not. I happened to be in the area yesterday while I was working :roll: , and stopped by their shop. Talked to a few people about different options setups prices. I'm needing new brakes soon, so I was just wondering about any interest in this, then I'll work out details. I saw a very nice 2 piece setup that got me drooling :yumyum: .
  2. gran0393
    gran0393 Well-Known Member
    lemme know how much your thinkin i might be interested
  3. LilRed
    LilRed Well-Known Member
    i am interested in it too. name the price and the time frame. plus i gotta figure out exactly what to do about my break setup.
  4. ImprezaWrx9
    ImprezaWrx9 Well-Known Member
    I'm down. My rotors are warped. ^^^ what he said, name the price and time frame. Don't know why my rotors keeps warping
  5. sapalas
    sapalas Well-Known Member
  6. Sogonerg
    Sogonerg Anteater
    I'm sure Russ will Chime in...soon he usually does this once a year, i believe
  7. WRX1
    Yep, I do a GB every spring. Make sure you talk to Mark Link and make sure you tell him that you are part of MNSubaru. He has a pretty good price for us anyways.
  8. stypert10
    stypert10 Well-Known Member
    I would like to be in for pads & rotors but it depends on how quick this would happen since i'm grinding down already...
  9. predavore
    predavore Well-Known Member
    I've got some 4 pots on the way, might be a good time to replace the rotors.
  10. Taras
    Taras BANNED
    i would be down for some sloted fronts. Can i use my old pads, they are only 2 weeks old.
  11. EtchyLives
    EtchyLives Well-Known Member
    Do you use a torque wrench to tighten down all your lugs to the same specs?
    Do you properly bed your pads/rotors when you change either of them out?
    Do you put on your emergency brake when parking when your brakes are still hot?
    Any one of those things (plus a host of others) can cause warping. Those are just the most common.
    edit: I may be interested in getting some of these for the Legacy. I will be doing some brake work next week and will have the chance to fully inspect everything and decide if I'm getting new pads/rotors or not.
  12. Underhill
    OK looks like we have interest, I'll work on putting something together.
  13. Justin
    Justin Well-Known Member
    i need some rear calipers and pads so i'd be in as long as we can get them asap
  14. bummpy
    bummpy New Member
    I've read that rotors rarely (if ever?) warp. It's typically uneven brake material build-up from improperly bedding in the brakes or letting hot brake pads sit on the rotor (leaving a brake pad "foot print" on the rotor).
    I think I posted the white paper explaining it in the gb thread from last time.
    I got cryo-slotted rotors all around with hawk pads. BIG improvement and highly recomended.
  15. EtchyLives
    That's what I was hinting at. Uneven wear from mis-torqued wheels, and not bedding in, and pad imprints on the rotors from parking with hot rotors.
    I bet you and I read the same white paper (StopTech, right).
    Ever since I started torqueing, bedding in properly, and parking my car using the gear instead of the e-brake I haven't had ANY brake shimmy or signs of warpage.
    Besides, bedding in pads is FUN.
  16. EtchyLives
    Yes. Just bed them in properly. (60 - slow, ten times in a row. Let brake system cool off to ambient, and repeat). A good place to do this in town is on 494/694 late at night.
    Do the first slow/fast/slow/fast on a deserted stretch, then cruise 1/2 the loop to cool the whole system. Repeat, and go home. It needs to be deserted because slowing down to ~5mph on 494 is not illegal... just irritating.
  17. Steve in Minnesota
    Steve in Minnesota Well-Known Member
    I would be down for this. I screwed up and missed the last one.
    At a minimum I would be down for another set of HPS pads....but I might be talked into some rotors.
    Steve
  18. Taras
    Taras BANNED
    lets talk about price.
  19. WRX1
    I am going to guess that Mark will come back with the same prices that he gave me in the spring. You could look in my thread, that will get you very close. Also Taras, if you don't have some kinda of performance pads, now is a good time to pick some up. Mark gives out KILLER deals on the hawk hps pads.
  20. Taras
    Taras BANNED
    do you think i will be able to sell my very lightly used oem pads and old rotors? how much will the pads be? Thanks
