First time Subaru owner - greetings!
Discussion in 'The Welcome Mat' started by Jason Kaasovic, May 16, 2013.
  1. Jason Kaasovic
    Jason Kaasovic Active Member
    Hi All,
    Just bought my first Subaru, 2006 Impreza Hatchback 2.5l.
    I will most likely be posting/searching through the forums for really basic info. Unfortunately I am a complete idiot as far as auto maintenance goes so expect a lot of beginner/dumb questions to come out of this account =D
    Take care and glad to have found a local board,
    Jason
    ps - have spark plugs coming up in a few thousand miles, already saw some conversation about how the recommended plugs really aren't the best for the car. Turn in Concepts seems to be a preferred vendor to some? Here's what I found on their site for my ride: http://turninconcepts.com/product_info.php?cPath=1_9_10_1357_1430_1494&products_id=1070
    That the right way to go? or OEM parts?
  2. BroCo
    BroCo Moderator Staff Member
    Welcome to Mnsubaru and grats on the new car! Post up some pics of the new ride. I would recommend OEM spark plugs for the car. Normally with Subaru's you can't go wrong with OEM stuff when it comes to maintenance. If you are at the point that you need plugs you should also do your rear diff fluid and trany fluid as well.
    Jason Kaasovic likes this.
  3. Jason Kaasovic
    Hey BroCo,
    Here's what I got from the previous owner:
    Transmission fluid -
    AMSOIL FGR Long Life Synthetic Gear Lube 75W-90 API GL-5 (100,000 miles)
    3.7 Qt
    32.5 ft-lb / 44 N-m
    replaced at 31k car now sits at 87k
    Rear Diff -
    .8 Qt
    32.6 ft-lb / 49 N-m
    replaced at 31k as well, 87k currently on car
    Thanks for the insights.
  4. BroCo
    Very clean looking car! Nice find.
  5. MNBD
    MNBD Member
    Welcome!
    Warning, these things are ADDICTING. I have a stock pile of Subaru parts, most I don't even need, but thought "Hey, I might need that sometime".
  6. Terry Ammerman
    Welcome. Nice find on the wagon.
  7. ofspunk7
    Welcome to the site. I would suggest swapping the car back to Extra S next time you do the transmission and diff. You can buy it from Morries or NF sells it as well.
    +1 for the OEM spark plugs.
    Edit... reading your miles, I would swap the fluid now. 54k is a long time to go.
  8. Jason Kaasovic
    Hey ofspunk,
    Thanks for the tip. You still think with 50k left I'm better off going with the Extra S though? I googled it and on the nasioc forum they listed a good vendor for the stuff as Fred Beans Parts: http://www.fredbeansparts.com/index.php/subaru-75w90-extra-s-gear-and-transmission-quart-bottle.html
    I'll have to bring it in for some work and spark plugs in 3k, might be a time to do it then I suppose.
    General reply to all others, thanks for the welcome :)
  9. ofspunk7
    You can get a better deal on the fluid locally. You can also save some money on the work locally... taking it somewhere like NF.
    Terry Ammerman likes this.
