Where are my fitment experts? Anyone know what generation this OEM springs/sway are off? (They fell into my hands so I'm not exactly sure myself). Thanks! -Art
got some calipers and a measuring tape? what's the diameter, length between endlink mounting holes, any PNs stamped on anything?
That looks like a front sway bar...the rear sb on the BRZ/FRS is straighter and has different mounting orientations. Due to the small diameter of the rear springs, they definitely look like they are from a subaru that has rear multi link suspension (08+ impreza, forester, legacy, outback, brz, etc) and not from one that had the typical mcpherson rear strut. As far as a specific year, make, or model, you're going to need dimension measurements at a minimum, plus [ideally] spring rate. Your easiest bet here might be tracking down the original owner and where they came from...
Looks like it's a 24mm diameter and 44.75" between the inside of the mounting holes, no part numbers stamped anywhere, but it appears there was a sticker tag that was ripped off. Thanks! Yeah that might be a good bet, I was more curious that anything, and was planning on listing them for sale for a few bucks at some point. -Art
