Follow up on 110oct. Now burning 92 non-oxy
Discussion in 'Off-Topic' started by FuJi K, May 18, 2005.
  1. FuJi K
    <font color="red">UPDATE! I'm now burning 92 non-oxygenated. I plan to run this from now on, is it good? Pros and Cons?</font id="red">
    .....I can already smell it burning. It was time for a fillup, so with note that it sort of helps cleans the injectors (Dads says) because of a higher rating octane, I decided to put a little in to see if there's a difference at all later down the road. He said that it should be put in like once a year.
    I put in 8 gals of 87oct, and 2.8gals of 110oct over at that one pump on Century and 36. What's my ups and downs again with this in the tank?
  2. Dream
    What gas station is this at? Leaded or non-leaded?
  3. kickin_81
    kickin_81 Well-Known Member
    Let's hope it was unleaded. :p
  4. FuJi K
    uh oh....it's leaded!
    Russ posted:
    "Short stop (citgo)
    2473 Division st. n
    North st. spaul
    92 non-oxy
    110 leaded"
    That's where I got it. I think O2's are going to go out now... Time to switch to unleaded 100oct.
  5. WRX1
    time to run 87 non-oxy till you get something in there to take advantage of the better gas. You will loose performance with anything over 87 in your na car.
  6. RallyNavvie
    RallyNavvie Well-Known Member
    Agreed with Russ. The higher flashpoint of the 100 octane won't burn as completely as 87 will in your engine. You're gonna run a little rich until that burns off.
  7. FuJi K
    So does it help clean the injectors some at all due to it being higher octane? I know there are fuels that is used to clean, but what about this 110 leaded and unleaded 100octanes?
  8. BlackDubRX
    BlackDubRX New Member
    If you want to clean your injectors, dump a can of SeaFoam into the tank.
  9. AWDimprezaL
    interesting, but i noticed my car runs like ass when i run anything else but 92, maybe its me, or maybe my 2.2 of fury likes high octane:D
  10. TSTRBOY2004
    oh what I miss about Australia... our lowest grade unleaded was 93 octane I think.. our good stuff is like 98 octane.... man I miss OZ gas
  11. Steve-o
    92.96 octane?
    I got a can of Torco from Russ and mixed it with a full tank, supposed to yield like 100+ octane. Hopefully Russ will have some time this weekend to tune and see if it actually made a difference. If it did, I'll be running a can in every tank this summer.;)
  12. Zola
    Zola Well-Known Member
    110 is definitely leaded. I thought Sunoco's GT100 was the highest octane unleaded gas sold, but a few people have reported 104 unleaded a few places around town in my thread on MNSC and here.
  13. Zola
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by wrxboy2003
    The number displayed on pumps on Oz is the Research Octane Number (RON). The number on pumps here in the USA is the pump octane number, (RON+MON)/2
  14. Steve-o
    There is an article in the latest SCC about octane boosters. Good read.
  15. Dream
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Steve-o
    <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Steve, you know of any gas stations that sell 100 oct or higher in our area??
  16. Steve-o
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Dream
    Nope, none.
  17. EnyceBoi
    EnyceBoi New Member
    I'm a chemical engineer and my advice is not to use 100+ octane for gas. Especially leaded. With higher ratings of octane it will take a higher temperature to fully burn the fuel. Since Impreza's reccomend using 87 in the manual its still safe to use 92 but not safe to use 100+.
    In high octane gas such as 100 or more the carbon chain is longer thus having a higher igniting point. Gas over 100 octane is for drag cars or airplanes whose engines reach those high temperatures. Also leaded gas is bad, if your car says "use unleaded fuel only." Running on leaded gas will produce deposits in your fuel system.
    So therefore the gas that you smell is the unburned gas that your engine wasn't capable of burning. My advice is to flush your system out and use a fuel injector cleaner.
    oh and by the way the myth of using higher octane gas to clean fuel injectors is false. your better off getting a bottle of STP cause its safer and cheaper. Tell your Dad not to use higher octane gas next time when he wants to clean his injectors.
  18. wall of tvs
    Also, leaded gasoline isn't very good for catalytic converters -- it tends to plug them up very quickly.
  19. Zola
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by wall of tvs
    Good point...it's also not great for oxygen sensors.
  20. RallyNavvie
    Catalytic converters? Oxygen sensors? Who needs 'em :p
    BTW the Sunoco 104 is unleaded, but I don't think we've got any Sunoco stations around. I believe there is one in Iowa, probably near that motorsports facility. MidAmerica or something like that?
  21. FuJi K
    nOOOO!!!!
    Russ, the 87 at Citgo is NOT NonOxygenated, only 91 is. I asked the ladies in there and that's what they said. Also there's a sticker on top over every 91 pump that lists that it's NonOxygenated. But I'm not sure if only the 91 is NonOxygenated because the sticker is placed in the same area at all the pumps.
    I rans the car HARD just to burn up the fuel, I even had a acceleration contest with a fellow VW guy in his supercharged hatch, of course I won, but the 87 is not NonOxygenated? [xx(]
    http://www.msra.com/NonOxygenatedFuel/NonOxyList08.16.04.pdf
  22. carbon_1
    carbon_1 Active Member
    Shell Station on Rockford Road in Plymouth has 100 unleaded and 110 leaded.
  23. BlackDubRX
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by carbon_1
    They live in cottage grove...
  24. AWDimprezaL
    cottage grove eh? ive had interactions with a few smokin hot women from there;)
  25. FuJi K
  26. Yang
    Yang Well-Known Member
    There is no PROS for your ej22!
    !--------------CONS----------------!
    1)Waste of $$:p
    2)Will not make you any faster;)
    3)Will not make you any louder[xx(]
    An ej22 with 4.111 don't need 92! :p
  27. RallyNavvie
    Yeah, you want to run the lowest octane possible that does not produce knock to get the most power out of your engine. You may be able to take advantage of the higher octane fuel if you get an engine computer and start advancing the timing, maybe get some different cams too.
  28. FuJi K
    Yes, understood about the octane rating, but what about it being non-oxygenated? Ray from teh Texaco on Rice St. told me that non-oxygenated fuel will be found in 91octane or higher.
    Where can I find non-oxygenated 87? Where ever I see that it's non-oxygenated, it's mostly 92 octane.
  29. BlackDubRX
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by FuJi K
    You more than likely WON'T find non-oxy lower than 92.
  30. fino22
    fino22 New Member
    There is a gas station on Central avenue. I think it is owned by Jeff Bobby and Steves. They have some really high octane (not exactly sure how high octaine) thats around $3.00+/gal.
  31. krees23
    krees23 Well-Known Member
    Here's a link for 100 Octane gas -
    http://www.racegas.com/gt100locals/default.asp
    From website:
    Sunoco GTTM 100, which has the highest octane rating of any street legal fuel, is now available at selected retail locations. Sunoco GT 100 is designed for high performance street cars, muscle cars, classics, street rods, motorcycles, karts and marine applications. Sunoco GT 100 contains no metallic compounds to harm catalytic converters or oxygen sensors. It contains a comprehensive additive package for greater engine protection and reduced fuel system deposits as measured by the BMW test. Sunoco GT 100 is also compatible with virtually all two-stroke synthetic and mineral based motor oils.
    GT 100 Unleaded is available at selected locations throughout the U.S. In certain areas, GT 100 Unleaded is available under the CAM2 GTTM 100 label.
    Minnesota Locations:
    Minnesota
    4 Seasons Automotive
    9950 County Road 9
    Plymouth, MN 55442
    (763) 553-9113
    Holiday Station Stores #341
    Hamline at Marshall
    St. Paul, MN 55104
    (651) 641-1045
    Kisch Oil Company
    17470 113th Ave North
    Maple Grove, MN 55369
    (763) 428-2887
    Speedway SuperAmerica
    5337 Shoreline Blvd.
    Store # 4194
    Mound, MN 55364
    (952) 472-5559
    Wayzata Automotive
    1022 Wayzata Blvd.
    Wayzata, MN 55391
    (952) 473-9451
