I pulled these out of my Escort Cosworth as I am putting the original stereo back in it. The head unit is in extremely nice condition and works flawlessly. 1. Alpine CDA 7894 radio/CD/MP3 with optional XM tuner and all necessary wires including the XM magnetic antenna. Details: • motorized, detachable face • switchable green/amber button illumination • blackout display mode — turns off display, reduces power consumption, and enhances sound quality • MaxTune SQ tuner • 18 presets • V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery (see "Wiring Note" in the Detailed Info section) • plays MP3 files on CD-R or CD-RW plus audio CDs, CD-Rs, and CD-RWs • Bass Engine® Plus (bass center frequency, width, and level, plus treble center frequency and level adjustments, as well as 4-channel digital time alignment and a 3-position, 12 dB/octave crossover) • Media Xpander™ • XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories • CD changer controls for Alpine Ai-NET changers only — add an Alpine changer to your receiver order, and save $$ with Crutchfield's package discount • optional auxiliary input • 4-volt front/rear/subwoofer preamp outputs • wireless remote • clock • 27 watts RMS/60 peak x 4 channels • CD frequency response 5-20,000 Hz • CD signal-to-noise ratio 105 dB • FM sensitivity 9.3 dBf Asking $70 2. Bazooka EL amplified subwoofer. Asking $30
To answer some of the questions I got in PM. Does this have aux in? For aux-in, you will need this part: http://www.crutchfield.com/S-Lb8ej48Skp3/p_500KCA121B/Alpine-KCA-121B-Auxiliary-Input-Adapter.html And then you will probably want one of these: http://www.google.com/products/cata...qxG8T_L2KsS-gAfDzcGDDw&sqi=2&ved=0CNQBEPMCMAI Is this plug and play for a WRX? No, you need an adaptor harness and likely a single DIN adaptor.
Found the combo for $9.95 through amazon for the aux in. http://www.amazon.com/Alpine-Ai-net...0T80/ref=sr_1_1?ie=UTF8&qid=1337726125&sr=8-1
