Hi All - Have a few items for sale that will make some much needed room in my garage, and might help you keep your rig running! All prices are best offer; I think the prices are fair, so if you don't agree, please say so...nicely if you don't mind. 2004 Forester XT stock used springs - normal wear, excellent shape, 105,xxx miles - $100.00 Not willing to separate set. I know people like to use these to lift their wrx's, should fit 02-05 based on my research. These still rode nice when I took them out, I went with a lowering combo for my Forester. 2004 Forester XT used KYB GR-2 struts - normal wear, unknown miles, moderate shape - $100.00 Not willing to separate set. These rode fine when they came out, no issues. One issue is that whoever installed these ground down the locking tab at the top of the strut cylinder; this doesn't cause an issue with performance, but just makes installation/removal mildly more complicated (I used a chain wrench to lock the top hat to keep the cylinder from turning). 2004 Forester XT master cylinder and brake booster, 105,xxx miles - $100.00 These are left over from my brembo swap, no issues what so ever. 2005 STi brake lines. used with unknown miles - $40? These came with my used brembo swap, but I have stainless lines to install still. Fuel Injector Clinic 1150 CC top-feed injectors with low Z injector driver - $150 (these were $329 new). I did not ever install these in my car, but they are used with less than 5,000 miles. Bought from another MN Subaru member who can vouch for their quality. Helix 860 cc top-feed injectors - $120 Again, I did not ever install these in my car, but they are used with less than 5,000 miles. Bought from another MN Subaru member who can vouch for their quality. Used Yokohama YK520 215/60/r16's set of 4 tires; well used but has a marginal amount of read left. Would get ya throgh the spring if you need something to get you by... - $50 (Mostly for the trouble of un-mounting them). The FXT rims they are attached to are likely spoken for. I will update the list of items available every time something sells.
OK all, I am not sure why my links aren't working, but if you click the below highlighted portion of any link it should work... EX: <a href="http://s1251.photobucket.com/albums/hh553/yuseforester/?action=view&current=100_3625.jpg" target="_blank"><img src="http://i1251.photobucket.com/albums/hh553/yuseforester/100_3625.jpg" border="0" alt="Photobucket"></a> Sorry ya'll!! Mods, can I edit this?
I also have a wish list going in the WTB section; I would be willing to trade if anyone has anything on my wish list http://www.mnsubaru.com/threads/wtb-wish-list.38497/
Adding a couple of items: Potenza RE92's 215/45/R17 tires - moderate tread left - $100.00 Invidia Up-pipe for 2002-2012 WRX/STi w/ EGT bung - $75 http://www.rallysportdirect.com/Invidia-Uppipe-Subaru-Models-inc-2002-2011-WRX-STI Random items: 2 - OEM used water pumps for 2.5l DOHC Turbo, both were in fine working order when removed, both have ~100k on them - Offer? 1 - OEM used 2.5l NA Phase 1 block water pump, worked fine when removed around 140k- Offer? 2- OEM timing belt pulley/tensioner sets, both used but in fine working order when removed - if they are helpful to someone, they are yours free of charge. 1 - Front and rear set of used OEM STi brake pads - probably about 50% life left - if they are helpful to someone, they are yours free of charge. 1 - Complete set of OEM 2004 FXT calipers, rotors and pads (pads and rotors are usable, cheap replacements if you need something and are broke!!), these are identical part numbers for 2004 and 2005 WRX brake parts - $150? 1- Stock BCS from a 2004 FXT, same part number as same model wear WRX - $5?
Oh, and I have about 3 gallons of Hartland Oil full synthetic 5W30 (http://www.bobjohnsonlubes.com/images/E0270901/HartlandBJLPrivateLabelProductLine.pdf) that I was running in my NA Forester when I still had it. If you give me $20 and come get it out of my garage I will be really happy, I just don't have anything that uses that oil anymore! It's sealed in a 20 gallon drum and is easily transportable.
Nice meeting you at Sheen's last night! Turns out we need an up pipe now after I accidentally rounded off the O2 sensor. Let me know if the initial buyer falls through.
For sure! It was good to meet you too! Sounds like your O2 sensor change out didn't go so smoothly Did you try a pipe wrench? Yes, I said pipe wrench... If you want to swing by my garage I have space and tools we could try... PM me if interested. If it doesn't sell I will let you know for sure!!
Gonna try a box wrench and a torch after letting it soak in PB blaster overnight this weekend. And I had confused the manifold with the up-pipe, so not sure if we're still interested in buying it, sorry. Still a newb on some stuff. But thanks for offering up your garage and tools!
For sure man; anytime you need a garage let me know...we've always got space for another subie! And seriously, if there is enough space, and you really are rounded off, try a plumbers wrench, the opposing teeth might just get you the tiny bit of grab you need to brake it loose.
Here is a picture of the Invidia Uppipe, used but in solid condition. Caliper Pictures, were in good working order when they came off, need a little clean up, but work solid. Thanks everyone! Buy my stuff so I can keep building my Forester Offers welcome!
Up-pipe sold to Travis! Nice car man, enjoy the up-pipe! Yokohama's sold to Nate! Thanks guys! P.S. I have a set of NIB pads that will fit into the calipers I have for sale.
Items still for sale, sold, or pending: 2004 Forester XT stock used springs - normal wear, excellent shape, 105,xxx miles - $100.00 --> Price Drop $75 2004 Forester XT used KYB GR-2 struts - normal wear, unknown miles, moderate shape - $100.00 --> Price Drop $75 2004 Forester XT master cylinder and brake booster, 105,xxx miles - $100.00 2005 STi brake lines. used with unknown miles - $40? --> Offers welcome Fuel Injector Clinic 1150 CC top-feed injectors with low Z injector driver - $150 (these were $329 new). --> Offers welcome Helix 860 cc top-feed injectors - $120 --> Used Yokohama YK520 215/60/r16's set of 4 tires --> Sold Potenza RE92's 215/45/R17 tires - moderate tread left - $100.00 Invidia Up-pipe for 2002-2012 WRX/STi w/ EGT bung - $75 --> Sold 2 - OEM used water pumps for 2.5l DOHC Turbo, both were in fine working order when removed, both have ~100k on them --> Offers welcome, if it saves someones day it's yours! 1 - OEM used 2.5l NA Phase 1 block water pump, worked fine when removed around 140k- Offer? --> Offers welcome, if it saves someones day it's yours! 2- OEM timing belt pulley/tensioner sets, both used but in fine working order when removed - if they are helpful to someone, they are yours free of charge. --> FREE is it helps anyone! 1 - Front and rear set of used OEM STi brake pads - probably about 50% life left - if they are helpful to someone, they are yours free of charge. --> FREE is it helps anyone! 1 - Complete set of OEM 2004 FXT calipers, rotors and pads (pads and rotors are usable, cheap replacements if you need something and are broke!!), these are identical part numbers for 2004 and 2005 WRX brake parts - $150? --> UPDATE AND CORRECTION: These are the 2002 style D721 (F) and D770 (R) setup --> Price Drop to $100 for a set of 4 calipers--> I now have two full sets for sale 1- Stock BCS from a 2004 FXT, same part number as same model wear WRX - $5?
Can you hold the struts and springs until I find out if they fit for my application? Also top hats included?
Today's Update: Items still for sale: 2004 Forester XT stock used springs - normal wear, excellent shape, 105,xxx miles - $100.00 --> Price Drop $75 2004 Forester XT used KYB GR-2 struts - normal wear, unknown miles, moderate shape - $100.00 --> Price Drop $75 2004 Forester XT master cylinder and brake booster, 105,xxx miles - $100.00 2005 STi brake lines. used with unknown miles - $40? --> Offers welcome Fuel Injector Clinic 1150 CC top-feed injectors with low Z injector driver - $150 (these were $329 new). --> SOLD! Helix 860 cc top-feed injectors - $120 --> SOLD! Used Yokohama YK520 215/60/r16's set of 4 tires --> Sold Potenza RE92's 215/45/R17 tires - moderate tread left - $100.00 Invidia Up-pipe for 2002-2012 WRX/STi w/ EGT bung - $75 --> Sold 1 - Complete set of OEM 2004 FXT calipers, rotors and pads (pads and rotors are usable, cheap replacements if you need something and are broke!!), these are identical part numbers for 2004 and 2005 WRX brake parts - $150? --> These are the 2002 style D721 (F) and D770 (R) setup --> Price Drop to $100 for a set of 4 calipers--> One full set still available, on set of fronts still available. 1- Stock BCS from a 2004 FXT, same part number as same model wear WRX - $5? I still have a bunch of brake pads available too, new (F&R) for the calipers (D721/D770) listed above and used Brembo OEM pads (F&R) + some good front pads for the D721 calipers.
