Sonic yella 03 5spd... very clean in and out, It has some upgrades... Invida up & down 3" exhaust, Dk blue 565cc,Walboro 255, FP 18g, GS 3port BCS, STI TMIC, silicon inlet & hoses, Tanabe springs & OS tune. View attachment 26394 The turbo is too big for the injectors so I built a 19t to try out on it. I had Midwest turbo clip the hotside wheel and balance the rotating assembly, I ported, Gasket matched & polished both sides. The 19T puts out 500cfm so about the same as a 16g.
I only pick up the ones that are in need of some tlc..... With yours going to JM for checkups I'm sure it's in perfect health! ( I can't believe your selling....It probably will be suffering from abandonment issues)
Swapped in the 19T today, perfect combo with the Dk blue 565cc injectors.... comes on about the same rpm as a stock td04 but achieves & holds 20psi until 6500rpm then tapers to 16. I'm going to build another one for the daily
