freaken code
Discussion in 'Modifications And Maintenance' started by Skarecrow, Dec 4, 2007.
  1. Skarecrow
    Skarecrow Well-Known Member
    threw the dang code again...
    i'll post them up when I get home and am able to pull them.
  2. AWDimprezaL
    Monticello.
    your car is bone stock?
  3. AWDimprezaL
    Monticello.
    I know you hate us, but it would be warranty, bring it in, ask to watch the car the entire time.
  4. Skarecrow
    it's not stock tho... stage 2, inlet, turbo back, spt intake.
    and now at 36k...
    I do have the gold plan tho... so I should be covered for 100k as long as the sensor isn't blown from something aftermarket, but I would seriously doubt that.)
    (I don't hate you guys :p I just had a bad day... )
  5. AWDimprezaL
    Monticello.
    ahhh i see, well then.
  6. Skarecrow
    i'll post up the codes when I get home...
    last time I check it it was 4 codes, all voltage low codes.
    and one fuel door open :p
  7. Skarecrow
    I would assume that since the spt in take / spt exhaust are oem, thats wouldn't be a problem...
    never had an issue with downpipe..
    inlet hasn't caused an issue...
    with that in mind... what will warentee NOT cover due to these parts?
  8. AWDimprezaL
    Monticello.
    that really depends on the tech, if you do bring it in, ask for brian, he is a suby guy himself, and a member here.
  9. Skarecrow
    you know if hes working today? or if you guys have any open time after 3:30 ?
