Free: Misc. Wrx parts and Rs parts
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by stiv5, Apr 24, 2013.
  1. stiv5
    stiv5 Well-Known Member
    All I have are these parts listed below so please don't ask if I have any other parts. If no one wants them, I will be throwing these stuff away soon. Some may have rust due to sitting in my garage for 3 yrs. PM me for more info to pickup these parts. Thanks.
    For '02-'05 Wrx:
    Oem Front sedan sway bar
    Oem Starter
    Oem Alternator
    Oem AC Compressor
    Oem Brake Booster
    Oem Windshield washer pump unit
    Oem Shifter with shift linkage
    Oem Rear differential cover
    Oem Front axle (Can't remember which side)
    Passagener side window control panel
    Keyless entry Unit control module
    For '98-'01 Impreza Rs:
    Gas pedal with throttle cable unit attached
    Oem Front sway bar
    Oem 13" Rear sway bar with mounts
    Oem Cruise Control Unit with throttle cable attached
    Oem Hood scoop back plate
  2. CarpalTomO
    CarpalTomO Well-Known Member
    I call dibs on the OEM hood scoop backing plate. Can you PM me an address and time so I can grab it from you please? Thanks
  3. ericthegoalieman
    Where are you located?
  4. stiv5
    Sorry, location is Maplewood.
  5. AspitFire
    Is the washer pump unit include the pump and the tank? if so i will take it.
  6. stiv5
    Yep.
  7. AspitFire
    ^done deal it doesnt leak does it? lol the one its replacing does.
  8. stiv5
    It shouldn't.
  9. Mace_five0
    Mace_five0 Member
    I'll take the starter and alternator. If their still available.
  10. CarpalTomO
    Thanks for hooking me up with the backing plate! Good guy and easy to work with!
    stiv5 and BroCo like this.
  11. stiv5
    Yep they are.
  12. stiv5
    Last bump before I throw away then tomorrow.
  13. PY_awd
    PY_awd Member
    ill take the keyless entry remote
  14. stiv5
    Sorry it's not the keyless remote, it's the control module for the keyless.
  15. 02_Rexxxy
    02_Rexxxy Active Member
    Did Mace_five pick up the alt? If not I want :)
  16. stiv5
    Yep he did.
  17. Credits
    Credits New Member
    Do you still have the compressor?
  18. stiv5
    Yep still do
  19. Shancaldazar
    I'll take (if you still have)
    Front axle
    Cruise Control Stuff
  20. stiv5
    Updates: these were given away already
    Wrx Ac compressor
    Wrx front sway bar
    Wrx alterantor
    Wrx front alxe
    Wrx starter
    Wrx washer pump tank with unit
  21. TongV
    TongV Member
    Do you by any chance have the stock sound system?
  22. stiv5
    No.
  23. stiv5
    These were also pickup.
    Wrx rear differential cover
    Wrx shifter with linkage
    Rs cruise control until with cable
  24. TongV
    TongV Member
    Do you have the audio system available?
  25. stiv5
    No, sorry I don't.
  26. TongV
    TongV Member
    OK, thanks
  27. choukhang
    choukhang Well-Known Member
    whats left..?
