Front axle replacement
Discussion in 'Modifications And Maintenance' started by prezawagon, May 19, 2007.
  1. prezawagon
    prezawagon Well-Known Member
    Redmond
    Any tips on replacing a front axle? I just noticed today that the inner cv joint on my wife's 99 wagon has a split boot and it's been spitting grease everywhere.
    thanks.
  2. Threshld1
    Threshld1 Well-Known Member
    SLP
  3. Dynapar
    Orono, MN
    pretty much i found that to get by without using a pickel fork on the ball joint. take off the ball joint nut and disconnect the swaybar. put a floor jack under the ball joint and jack up. then hit down on the control arm with a masive hammer.
  4. prezawagon
    Redmond
    Well, it wasn't too bad, the driveaxle nut was a pain to break loose, it was rusted on pretty good. Otherwise the old axle came out ok. I didn't take the ball joint apart, I just unbolted the strut and that gave enough room to get the axle out. The new axle went in easy, but I had trouble getting the new pin in. It looked perfectly lined up, but I had to take the axle back out and rotate it 180 on the transmission, then the pin went in ok. Took about 2 hours total. I need to invest in a better set of punches for dealing with those pins, and a 32mm impact socket for the axle.
