Front Sway Bar Upside Down?
Discussion in 'Modifications And Maintenance' started by Andrew, Feb 3, 2008.
Is this FSB Upside Down?
Poll closed Feb 4, 2008.
  1. Yes - you messed up dummy.
    18 vote(s)
    94.7%
  2. No - how much do you charge to do installs?
    1 vote(s)
    5.3%
  1. Andrew
    Andrew New Member
    I can't shake this dang clunk. My FSB is hitting the control arm. I wonder if it was installed, by some idiot, upside down. Good I thing I didn't charge myself for the labor when I installed it.
  2. fobiawrx
    fobiawrx Fabiola
    sure looks like it to me.
  3. TSTRBOY2004
    I'd say swap it left to right... it looks 180* off HORIZONTALLY!!!
  4. fobiawrx
    fobiawrx Fabiola
    if you swapped the sides around it would be right.
  5. fobiawrx
    fobiawrx Fabiola
    and the poll says 100% that its wrong...
  6. TSTRBOY2004
    Here's how it should be, so yeah 180* horizontally... (just went out and took this pic for an example)
  7. Andrew
    Andrew New Member
    Thanks team. I'm glad I've found a solution, but not so happy about flippinng the flippin' bar around.
  8. mlgez
    mlgez Well-Known Member
    Yea looks a little scary the way you have it. Looks real close to the steering.
  9. Andrew
    Andrew New Member
    out to the garage...
  10. Bullwinkle
    Yeah, my whiteline went under the control arm. Looks like it's installed wrong.
  11. Natural2JZ
    Natural2JZ Well-Known Member
    lol..
  12. piddster
    You might want to get your alignment checked. You will eat up your tires in a hurry if you bent your tie rod.
  13. Chux
    I can't tell what's happening in this picture, it's just so small and low resolution. do you think you could make it any bigger? :biggrin:
  14. pbedroske
    pbedroske Well-Known Member
    Don't worry, I did the same thing with my whiteline fsb. Maybe there's something wrong with their directions?
    Fixed it with no damage done to my alignment.
  15. Andrew
    Andrew New Member
    all fixed up, no more noise. it feels like christmas i'm so happy. and the steering wheel feels a little lighter too.
