Frozen Rotors GB 2011 - Discount codes inside
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by WRX1, Apr 17, 2011.
  1. WRX1
    The GB is a go for our standard discounts. 10% off of a set (2 rotors and set of pads) and 15% off all 4 (4 rotors and 2 sets of pads). Again you can check out their website for current pricing and apply the correct discount to get your pricing.
    At this time, they are going to be rolling out a whole new website and store this coming week. So after next week, Mark will get me a discount code for the new site. Until that time, feel free to give Mark a call and jut tell him you are part of the MNSubaru group buy.
    Hi Russ,
    I have the new site up and running. J I put in two coupons with one at 10% off for two rotors and one set of pads(fr1010). And then one at 15% off if they order four rotors and two sets of brake pads (fr1015).
    They will find a place for the coupon code in their shopping cart.
    Frozenrotors.com
    Mark Link
    952-746-8880
  2. Mr.Tran
    Mr.Tran Well-Known Member
    So in order to receive the discount we have to buy pads also?
  3. Mr.Tran
    Just talked to one of the people at Frozen rotors. If you plan on purchasing just rotors it's a 10% discount.
  4. WRX1
    Ok, thanks. I haven't had a chance to talk to Mark to verify.
  5. Mr.Tran
    No problem Russ. I figure you got enough stuff to do. (like answer my stupid e-mail questions, lol)
  6. JasonoJordan
    Online
    Im assuming no discount on pads or is it 10% on them as well for a pair and 15 for front and rear
  7. Mr.Tran
    I'm not sure, I'd call and ask. I only asked about rotors.
  8. JasonoJordan
    Online
    sounds good i plan to get front pads either way because the pads i want i can get through them for 5 bucks more then import has them listed for so it would be nice to just pick it all up rather then haveto wait for it 2 ship in
  9. Rideride2
    Rideride2 Member
    I went to a performance brake class on Saturday at First Gear Garage and one of the guys from Frozen Rotors was there teaching the class. I learned a lot of information (which isn't hard for me right now) but had a question after the class. So cryogentically freezing your rotors does what to them? Makes them last longer or dissipates heat faster or what?
  10. SurlyOldManMN
    I did too... Should have said hi to the guy with the mnsubaru lanyard! ;)
    It increases longevity, supposedly. I would have liked him to go in to some high level explanation of what freezing does to the structure of the metal that specifically increases durability without sacrificing other qualities. I expect it isn't that different than annealing/tempering. Exposing metal to various temperature differences in a specific order causes the changes to internal structure yielding various qualities of strength/hardness.
  11. Rideride2
    Rideride2 Member
    Haha nice! Yea I didn't even notice, I was probably distracted by the GT3. I'm just getting into the whole Subaru thing and a few of my friends are on these forums so I thought I'd join and try to suck up as much knowledge as I can and maybe spit a little back out.
    Good to know though that they last longer, just how much. Obviously it's dependent on driving but as for now my car is just a daily driver. From the sounds of it you really only need frozen rotors (cost effective) if you have a high performance car with HP to back it up or are road racing. Maybe?
  12. WRX1
    First post has been updated with the discount codes.
    As for the process. What the freezing does is align the metal molecules to create a tighter knit to the metal. That will create a more durable surface that can handle the heat better. The key basics to getting brakes that work is having something that can handle the heat (key word being heat). Biggest differences in pads is what heat ranges they work in. You can get cheap pads that will stop your car. Where the difference comes in is what happens after the 1st stop, then the 2nd stop and so on. If you never generate and real heat in the pads/rotors, cheap brakes will work. If you are always in stop and go traffic, doing track days, autocross, etc, you will want something that can handle the extra heat.
    As for longevity, I had 85k on the GF's lgt with cryo rotors and hawk hps pads all the way around. The rotors had over 60% life left on them. I was to lazy (and time constrained) to get them turned before I swapped out pads. The only reason I wanted to turn them was to make sure the new pads had a nice clean new surface to bed in on. And when she drives her car, she is not easy on the brakes. Stop and go traffic is go real fast and stop real fast and never left off the brake until you are ready to go real fast again. So between constantly creating new hot spots and not being generally easy on the brakes, I think they did a outstanding job.
  13. jolson05
    jolson05 Member
    Did you ever get an answer on what the discount is on just the pads?
  14. Rideride2
    Rideride2 Member
    How can one argue against that? Look's like I'll be investing in some of these come time to do my brakes. Thanks!
  15. WRX1
    Back to the top for the people who don't look past the first page.
  16. RallyNavvie
    RallyNavvie Well-Known Member
    I still can't get a straight answer from the distributor on rings. Where the hell does Stoptech get their blanks?
  17. 02blubru
    I take it we can just order these on our own then and still get the discount unlike previous years???
    thanks again for setting this up Russ.
  18. JasonoJordan
    Online
    You are correct when u order just say u are with mnsubaru and u get the discount
