FS: 02-05 WRX ACT Street HD Clutch and Street Light Flywheel. USED Other misc. Parts
Discussion in 'For Sale : Car Parts' started by JasonoJordan, May 17, 2012.
  1. JasonoJordan
    To start i know its hard to move used clutch parts as who would want to put used parts in when its such a pita to change the stuff out. That said these parts were just in to good of shape to just throw away. Have been in the car for apx. 30k. Throwout bearing was making a ton of noise and needs to be replaced and the pilot bearing dosen't feal the best. That said i would highly reccomend anyone getting these to replace both bearings or if you want for a extra $100 i can get you oem replacements for both bearings.
    Clutch Package. $350 obo
    1- ACT Street HD Clutch Disk-$60 obo
    1- ACT Street HD Pressure Plate-$150 obo SOLD
    1-ACT Street Light Flywheel-$150obo SOLD
    1- Broken 02 Wrx Gauge cluster.(ex kicked it when it was sitting on the floor and the needles dropped to pointing straight down. might be able to be fixed but figured id sell it for the glass and plastic enclosure.-$35 obo
    1-02-05 WRX shift fork-$30 obo SOLD
    1-05 sti lateral Link-$30 obo
    2- 05sti Parking Brake Cables-$30 obo
    1-IC Sprayer button-$20obo
    Pictured Spring is a little loose but should not be a issue.
  2. JasonoJordan
    Also want to add the clutch hooked up just fine it was just a issue when you would shift because of the throw out bearing. Also all the clutch parts were installed at the same time so they are all bedded properly. With correct clutch break in.
  3. JasonoJordan
  4. JasonoJordan
    All are obo
  5. JasonoJordan
  6. pbedroske
    pbedroske Well-Known Member
    still have flywheel?
  7. JasonoJordan
    yes i do. it has some surface rust but i can clean it up tonight if you like or you can take it how it is.
  8. Talonted
    Talonted Well-Known Member
    can you post a pic of a straight edge on pressure plate face, and how do you go about replacing the throw out bearing?
  9. JasonoJordan
    i will try and get the pressure plate cleaned up as well clear of surface rust and place a straight edge on it. The throw out bearing just pops out of the fingures that hold it in. For a better description of how that works and the shape that these parts are in im sure sheen would be able to answer your questions as he was the one that removed the parts from my car when i changed over to the 6spd setup.
  10. JasonoJordan
    Cleaned up surface rust on flywheel [​IMG]
  11. JasonoJordan
    Cleaned up.surface rust on pressure plate. [​IMG][​IMG]
    Hard to get a good.image of straight edge on it but it was flat and had no weird wear on flywheel preasure plate or clutch disk. All 3 items were brand new so they have been mated to each other with proper 500 mile clutch break in.
  12. JasonoJordan
  13. JasonoJordan
    clutch pressure plate and flywheel sold.
  14. JasonoJordan
    With clutch also gave away 5spd shift fork. that can be listed as sold as well.
