FS: 02 WRX 5 Speed bad 2nd gear
Discussion in 'For Sale : Car Parts' started by Subaru004, May 26, 2014.
  1. Subaru004
    Subaru004 Well-Known Member
    $150? OBO not really sure what this is worth if anyone is really interested at all
    Just bought the car with a bad second gear, drove it home and it drove and shifted normal for 1, 3, 4, and 5 just had to skip 2nd. Transmission is currently somewhat apart as I was going to rebuild it but found out parts are a little more spend then i would like to invest. Also have a new gasket for transfer case and shift shaft seal. Took some photos before I put it back together, it is now assembled without the transfer case installed on it. Everything else besides seconds appears to be in decent shape no metal shavings were found in the transmission only 4-5 teeth that were broken off and a couple small chunks I'm assuming from the teeth as well.
    You can PM me on here or call/text Max at 952-836-5078
  2. Subaru004
    Bump need some space in the garage! May be going to the scrap bin soon
  3. Subaru004
    bump one last try offer me anything
  4. Subaru004
