FS: 02 WRX 5 Speed Transmission and Clutch Kit
Discussion in 'For Sale : Car Parts' started by Subaru004, Feb 16, 2016.
  1. Subaru004
    Subaru004 Well-Known Member
    $200
    02 WRX 5 speed for sale. Transmission runs and drives in all gears but has a rotational clicking noise heard intermittently, not sure if it's just a bearing noise or other internal issues. I have a video of the transmission driving through all 5 gears and tried to take a video of the clicking noise but is kind of hard to hear in video. I ended up replacing the transmission with another used tranny just because i wasn't sure what the exact problem was and didn't want to make it any worse.
    $150
    I thought I needed a clutch but it turns out the driver rear axle had popped out of the diff causing the car to feel like it was slipping. Clutch kit was in the car for under 500 miles. Its an Exedy kit but not 100% sure on the model number or what it fits in(was not installed by me previous owner had it installed). From my research I believe it could be the kit W0133-1653770? Only part number I can for sure verify is the pressure plate Exedy FJC521. Again not 100% sure but it seemed to fit fine in my 02 WRX when it was removed and replaced with an Exedy OE replacement kit. Kit includes pressure plate, clutch disc, throwout bearing, and pilot bearing.
    Call, text, or PM Max at 952-836-5078
  2. Subaru004
  3. Subaru004
    Video does not want to upload so I can text it if interested
  4. scoob
    scoob Well-Known Member
    texted you
  5. Subaru004
    Tranny sold. Clutch kit still available
  6. Subaru004
    Clutch kit is sold.
