FS: 08 WRX RSB with Endlinks (15mm)
Discussion in 'For Sale : Car Parts' started by cdenny, Aug 12, 2014.
  1. cdenny
    cdenny Member
    I upgraded to a 19mm STI rsb with rallitek endlinks (went from none on the OBS, to 15mm, wasn't enough). Hatch version if it matters.
    Comes with bushings and endlinks.
    $40 obo Twin Cities area.
    Sitting next to the 19mm STI bar
  2. cdenny
    cdenny Member
    Bump, I have a feeling no one will want to buy this, so if anyone can actually use it they can have it for a buck two-eighty.
  3. sneefy
    sneefy Well-Known Member
    Hmm. I have an OBS right now with no rear sway. Would I just need the brackets and bolts in addition to this?
  4. cdenny
    cdenny Member
    Yes. Let me double check to make sure I have the rubber bushings. You would need two brackets to connect bushings to frame, four bolts to bolt it together, and two bolts and two nuts to attach the end links to the rear lateral links. There is a thread on Nasioc that has all part numbers and a guide but the forums are down right now. Good upgrade as you can eventually upgrade the bar and ends inks but reuse the hardware. I installed it the first time without ramps, pretty easy when you figure out how to angle it in to thread it above and over the exhaust.
  5. cdenny
    cdenny Member
    Have the bushings, still up for grabs.
