FS: 16gb Nook Tablet
Discussion in 'FS: Everything else' started by WRX1, Jul 16, 2012.
  1. WRX1
    This is NOT the nook COLOR, but the nook TABLET.
    http://www.barnesandnoble.com/p/nook-tablet-barnes-noble/1104687969?ean=9781400501465
    Dual core processor, 1gb of ram, multi core GPU (Rumor is 4 core) and 16gb of onboard storage plus SD card slot.
    Currently running Clockwork recovery and CM7.2 gignerbread, but the pics are when I had CM9 Ice cream sandwich.
    Basically, this has been hacked from a normal B&N Nook to a full fledged android tablet. Everything works on CM7.2 and almost everything works on CM9. The current cm9 is running the old 2.6.xx kernel while they are programming a 3.0.xx kernel from scratch. I just noticed that they already have a mostly working jelly bean port running on it.
    You can also dual boot the system, so for a little while I was running cm7.2 (on the sd card) and cm9 from emmc. I went back to cm7.2 so the GF could mess around with a tablet for a bit and cm7.2 is currently the most stable rom for the nook.
    $200 or B/O
    I can also spend a bit of time with the buyer (if needed) to show you how to flash new roms and convert back and forth. I will also include 2 micro sd cards (8gb class 4) that you can use for running different roms or dual booting. I can also revert back to the stock B&N firmware if you would like. I also have original box and paperwork and it has a screen protector installed.
  2. WRX1
    Anyone?? Offers?? After this weekend it is going up on swappa.
