FS: 17" Wheels, HKS Coilovers, and some other stuff
Discussion in 'For Sale : Car Parts' started by Korsch_RS, May 3, 2009.
  1. Korsch_RS
    Korsch_RS New Member
    Duluth MN/Houghton MI
    Wheels: SOLD!
    SSR GT-2 semi-solid forged aluminum wheels. These are very light, about 18 lbs each. 17x7.5 with a +50mm offset. 5x100 bolt pattern. They will fit all 93+ subarus except SVX and STi's with a 5x114.3 bolt pattern. Out of production, and retailed for $300 each, I bought them closeout for $250 each. All are in very good condition, no curb rash, and no bent rims. There are some very minor surface scratches that I couldn't see until I was 6 inches away cleaning them. Some tar stuck on the insides from roadwork. Come with black aluminum valve stems. Do not come with center caps or tires.
    Coilovers: SOLD!
    HKS Hipermax coilovers that came off my 2001 subaru impreza 2.5RS. 6kg/mm springs front and rear (336 lb/in). Dampers are 15-way adjustable if I remember correctly, and also the whole damper is threaded, so they are adjustable for both spring preload and overall length, so the height can be adjusted without affecting spring preload. Retail is over $1500, I bought them used 30,000 miles ago. Only had 20,000 miles on them when I bought them. All the rust is surface rust, an hour with a wire wheel and a can of spray paint and they will look brand new. Come with front camber plates (can adjust to over 3* of negative camber!), and rear spherical bearing topmounts. These are also significantly lighter than stock suspension.
    Crank Pulley: $15 OBO.
    No name brand, stock diameter, lightweight aluminum crank pulley. Never installed.
    Ebay Crossover Pipe and Up pipe combo: $40 OBO
    Never installed, designed to fit EJ20. Was going to swap my Impreza, but decided to buy a factory turbo car instead, so I have these leftover.
    Kosei K1-TS wheels: $200 OBO
    17x7, 5x100, +50 offset. about 17-18lbs (Tirerack says 15lbs, but I weighed them and they were at least 17)
    Painted "copper" (metallic orange-ish color), no curb rash, but I believe 2 of the 4 wheels have very slight bends, they are still true. They still hold air and there is no vibration when driving. Come with center caps and very worn BFG g-force sport tires (215/45/17).
    Here's a few old pics of them on my car so you can get an idea of the color:
    I go to school in MI this summer, but will be in Duluth fairly often on the weekends, so pick up in Duluth is preferred.
  2. KSAL
    KSAL Well-Known Member
    Here
    Just curious if this is a typo.... GL with the sales
    Sorry i thought it was saying it WILL fit STi's... reading>me
  3. Korsch_RS
    I'm pretty sure that's true. Are there any other 93+ Subarus that don't have a 5x100 bolt pattern?
  4. Chux
    Independence, MN
    technically the loyale went until '94 with the 4x140. and the tribeca has a 114.3 as well......but yea.
  5. G_2.5rs
    G_2.5rs Well-Known Member
    Mpls, Mn
    ill take the pulley if its still forsale when i get outta school....(may 26th)...
  6. accord917
    accord917 Well-Known Member
    pmd you about the SSR :)
  7. BBsRS
    BBsRS Well-Known Member
    On the Road
    Pm me if the SSR's aren't taken.
  8. Korsch_RS
    PM's replied, interest in the SSR's and Coilovers
    If the pulley is still for sale on the 26th, then it will be in MI with me, and there may be a small shipping charge.
  9. Korsch_RS
    Bump!
    Sales pending on the SSR's and the coilovers, but there is still a lot of other goodies for sale!
    Anybody in Duluth, I'll be there tomorrow through Friday, let me know and you can come take a look at anything!
  10. Korsch_RS
    coilovers are sold!
    everything else is still for sale. I will entertain any reasonable offers!!
  11. Korsch_RS
    Bump
    Everything but the coilovers is still for sale, I'll be in Duluth this weekend so now is the time to buy.
    And all the prices are lower, and they are all OBO, so send me an offer!
  12. ridexstraight
    ridexstraight New Member
    u.p. of michigan
    korsh your in houghton? ive never seen your car around?! pm me or something!
  13. Chux
    Independence, MN
    how long are you in town for? if I can scare up the cash, I might grab the kosei's from you.
  14. BBsRS
    On the Road
    Pm'ed you.
  15. Grayguy
    Grayguy Well-Known Member
    Hicken House
    Korsh, I'll take the pulley, I can get it this weekend sometime. do you still have my number?
    Also, are you still selling the RS?
  16. Korsch_RS
    SSR's sold.
    Not selling the RS, keeping it for the winter. Someone else is interested in the pulley, but I'll let you know if he doesn't get it.
    I've also got an up-pipe and crossover pipe that might fit your legacy.....hint hint
  17. BBsRS
    On the Road
    SSR's are mine! thanks again.
