FS: 1984 Subaru Brat (Project)
Discussion in 'For Sale : Car Parts' started by Dynapar, Oct 13, 2008.
  1. Dynapar
    I do not have the time to work on this project anymore. As much fun as this is (truly a good time) I would like to sell it. I am prioritizing and right now some extra $$$ to throw towards my other Subaru would be nice. I still think that it would be an awesome project car and would be amazing for tackling mud pits.
    Details:
    1984 (2nd Gen) Brat
    23X,XXX Miles on the Odometer
    1.8L EA81 motor Runs good
    No power steering (didnt come with it from factory)
    No A/C (didnt come with it from factory)
    Newer engine installed (unknown miles, but does not have all 23X,XXX miles on it)
    Black w/ Turbo decals (not turbo, never was)
    4 Speed Manual, with Dual Range 4WD
    Good:
    Car runs great, just did a tune up (new plugs, cleaned distributor)
    I have put less than 100 (fifty) miles on it since I bought it 2 years ago
    Brand new Rough Country struts in the rear (for a 2.5" lifted TJ Jeep)
    Has a complete 4" lift. (custom block all round, and FastMatt custom front strut extensions)
    Re-Clocked rear torsion bar
    Hubs have been converted to 6 lug (Some lugs are loose, from when the new ones were pressed in)
    Has 235/75/16 (will double check size) tires which are in good shape with decent tread left
    Comes with full size spare
    New gas tank installed (still has small leak, by filler stem)
    Has custom high strength rear bumper (comes with parts to make a front one)
    Comes with some spare oil filters, clutch, pressure plate
    Current clutch is in good shape, grabs very nicely and does not slip even with big tires
    Comes with a battery quick disconnect installed
    Comes with extra LOW miles (30,XXX) motor
    Comes with SJR Adapter plate (so you can bolt up any EJ motor in)
    New rear seal on transmission, doesnt leak any gear lube
    T-Tops in excellent shape
    Brakes work well (no ABS)
    Comes with extra rear window
    Has new windshield wiper blades
    Comes with Jumpseats and head rests!!!! (need seat belts to be road legal)
    Comes with a box of misc. parts
    Radio works well
    Bad:
    Minnesota car.... Rusty.
    -Bed needs patches welded in
    -Body panels rough around the edges
    -Unibody requires reinforcement for anything more than casual driving
    No interior carpet (old stuff was nasty so I removed it)
    Ignition switch is busted, will need a new one if you want to use a key to start it. (I have a special method for starting and stopping it)
    2 Broken exhaust studs, means a big exhaust leak at the heads
    Cracked windshield
    Very small oil leak
    Oil pressure sending unit not hooked up (solder 1 wire to fix)
    Rear alignment is very..... special (would recommend trailering until fixed)
    Does not come with tailgate
    1 low beam is burned out
    Been sitting awhile, probably needs a jump start
    Pretty much with a welder and some scrap steel, it would be very easy to fix up the rusty areas. Use the adpater plate to put an EJ22E in it, and it should be a fairly capable trail rig. I have taken this through the mud before and does very well. If it had the extra power from an EJ series motor and some more aggressive tires it would be unstoppable.
    Price: $1500
    What it looks like now.
    An example of the rust areas in the bed that need to be patched.
  2. strangefamous
    price?
  3. Dynapar
    I added it to the first post.
  4. curly2k3
    dang it, one of the ones i have always wanted
  5. imprezars
    imprezars BANNED
    pm me price. friend with cash in hand.
  6. 02blubru
    1500 is the price. it is in the first post!
  7. imprezars
    imprezars BANNED
    oh, damn. saw it today at like 2 and there wasnt a price.
    most def will get back to you.
  8. 02blubru
    its not mine, talk to the guy who started the thread. I was just helping out.
  9. Chux
    I think part of me just died. :(
  10. subynate
    subynate Well-Known Member
    ooooo this could be sooo fun bump for you
  11. Dynapar
    Send me a PM or not.....
    I know, Its sad. I just dont have the time or funds to put towards it. The money I that I can recoup from it will be used to help keep my impreza in good shape. I have rust on both A-Pillars which must be taken care of ASAP. Also I only have room for 2 cars, and hopefully soon I am going to start looking for something new(er).
  12. Dynapar
    Bump Brat is officially for sale now.
  13. Impreza 2.2 T AWD
    Impreza 2.2 T AWD New Member
    Its could a seriously sex ride
  14. Dynapar
    Bump, Brat is still for sale.
    I will be working on this soon. Finishing the lift, doing the 6 lug conversion with wheel and tires, fixing the rust holes in the bed, and doing the custom front bumper.
  15. Dynapar
    Bump. Brat needs a good home.
  16. bubba_crx
    bubba_crx Well-Known Member
    that'd be a fun project!
  17. Dynapar
    Bump: To The Top.
  18. 02blubru
    do you have any pics of it not on a stump??
  19. petrakov08
    petrakov08 Well-Known Member
    sexy. if I had the spare money.
  20. Dynapar
    Bump
