This 1995 mk3 VW Golf is in great condition. It has a ton of recent maintenance, I have receipts of thousands of dollars in work done. Clean Title. It gets 30Mpg. The interior is very clean. Some minor spots of rust, but zero rust on the strut towers. Has brand new A/S tires. The car does great in the snow. A fun affordable car with lots of life left in it. The only problem with the car is that it won't shift into 4th gear. It runs and drives just fine in the other 1-3 gears but will need a little work on the transmission. Come test drive it! 1995 VW Golf GL 5Dr hatchback. 143k Miles. 2.0l 4 cyl engine. 4 speed auto trans. Clean Title in hand. Cash Only, $1600 firm. I am taking into account work needed, the Nada value of the car is $2,525. Recent maintenance completed~ 142,395 miles: General Altimax Hp all-season tires-$340 139,000. New brake light switch-$130 136,000. New O2 sensor, New spark Plugs cap wires and rotor.$400 133,000. New front wheel bearing and Hub. $500 131,000. 1/14/13 Replaced oil cooler seal, rear shocks, front ball joints, Front brake pads, serpentine belt and pulley, replaced breather hoses, and oil change. $1500 130,000. New Starter$400 $3,270 In recent work done to the car in the last couple years, I have receipts of work. has had other stuff done as well like a new muffler, and has had the Timing belt done by the previous owner. I'm asking only $1600 for the car as it is. Cash only. NO checks or bank checks. I am pretty firm on my price since the car is really in very nice condition and has so much maintenance work done to it. Issues with the car~ There is a check engine light on. Has been for a long time but has always run very nice. Airbag light is on. Some body rust, rear hatch is rusting at bottom. Couple missing pieces of trim. Some minor dings dents. Has some small hail dents on roof and hood. But overall very clean body with original paint. The radio is in safe mode. I don't have the radio code so it is currently not working. But all you need to do is get the code from the VW dealership. They should give it to you for free. The Main issue is the Transmission wont shift into 4th gear. So the rpms are high when on the highway going like 60 mph, and its a little slow starting from a stop. Guessing it could be fixed or a rebuilt used transmission could be installed for under $1000. But the car runs and drives just fine. Email- or call #952. Two 1 seven. Seven 3 7 zero. If you want to see and test drive the car. Located in Eagan,MN
